Removing the intake resinator
Old Nov 14, 2003 | 08:05 AM
lastlude2k1se's Avatar
Default Removing the intake resinator
I've heard that doing this will actually hurt performance on the type-R, I don't see how it will but is this true?
If I remove the resinator, where should I place the aluminum air duct for best results?
Also what is the best bang for your buck drop in filter? K&N? Spoon?
Thanks!
Old Nov 14, 2003 | 08:15 AM
Willard's Avatar
Default Re: Removing the intake resinator (lastlude2k1se)
mine has been out for 2+ years....
no ill effects that I can see. (only a dirty filter)
Old Nov 14, 2003 | 08:53 AM
Default Re: Removing the intake resinator (Willard)
I see.........
Will the K&N drop in filter fit perfectly for the R? I know on the website it says for all models but I heard of people having to modify it a bit to make it fit, is this true as well?
Old Nov 14, 2003 | 09:26 AM
Anyone else have any insight on this setup? Is it worth it? Better than a CAI or SRI? I know for sure that this will have better throttle response over a CAI.........opinions please.
Old Nov 14, 2003 | 09:41 AM
Asahi's Avatar
You might see a no power loss from running the K&N on the end of the tube with no air box but if you remove the resonator in the wheel well and leave the air box this is what you will find happens. I had these sam,e results on 2 different Type-Rs. This is the most exxaggerated result but I can't find any other dyno runs with these conditions.
The first run is stock with K&N filter. The other run is a few minutes later with no changes except the resonator in the wheel well removed. Sorry the pic is so small. The First run was 158.65 and the second run was 150.92. Figure about a 7.5 hp lossa. The other time I did this test it was a 3 hp loss.
Old Nov 14, 2003 | 09:52 AM
Default Re: Removing the intake resinator (Asahi)
Hmmm interesting. Any explination as to why this happens? What are you running for intake right now?
Old Nov 14, 2003 | 09:58 AM
Asahi's Avatar
I'd say it is a combination of air flow restriction and air temperature.
I run an Icebox. If I didn't have this I would stay fully stock with K&N drop in.
Old Nov 14, 2003 | 11:26 AM
I don't get why the spoon integra has that setup then??????
Will this not work for our cars? Is this not pretty much an icebox setup?
Old Nov 14, 2003 | 11:29 AM
Stock R's Avatar
Been there, done that.
It's louder... that's about it. Either just keep the stock intake setup or get a real aftermarket intake.
Old Nov 14, 2003 | 11:43 AM
Hmmm, what aftermarket intake system shows to be most benificial to the ITR?
Old Nov 14, 2003 | 12:31 PM
type r 01-1063's Avatar
Default Re: (lastlude2k1se)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastlude2k1se &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, what aftermarket intake system shows to be most benificial to the ITR? </TD></TR></TABLE>
Mugen!!!
Old Nov 14, 2003 | 12:50 PM
Default Re: (type r 01-1063)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type r 01-1063 &raquo;</TD></TR><TR><TD CLASS="quote">
Mugen!!!</TD></TR></TABLE>
I was afraid of that answer
MUGEN=$$$$$$$$$$$
Old Nov 14, 2003 | 02:41 PM
jond's Avatar
Comptech Icebox w/ stock arm(changing the arm from the box to the TB doesnt seem to make a difference).
Old Nov 14, 2003 | 02:50 PM
itr-j's Avatar
Default Re: (jond)
stock intake with plumbing pipe, or what do i use to get some cold air into a short ram
magic hat #9's Avatar
Default Re: (jond)
you can remove the resonator, break the "milk jug" in half, and replace the pipe from the airbox down to where the resonator was. it's easy, free, and should produce results about as good as the comptech ice box.
Old Nov 14, 2003 | 02:55 PM
Bbasso's Avatar
Ahhhh just pic up a AEM CAI used for 100-150 and have the Vtec loudness everyone fears
Old Nov 15, 2003 | 08:01 AM
Default Re: (Bbasso)
I'm not so fond of the AEM CAI, had it on my last car........Gonna go the stock box route and use the aluminum air duct to simulate an ice box, worse case senario I will just put back the stock resinator if the air duct seems to be more hurtful than beneficial......spoon air filter here I come
Old Nov 15, 2003 | 08:11 AM
Misfit's Avatar
J's racing is what I have and I love it.
Old Nov 15, 2003 | 10:29 AM
IGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastlude2k1se &raquo;</TD></TR><TR><TD CLASS="quote">spoon air filter here I come </TD></TR></TABLE>
If your worried about spending too much money on the Mugen intake, why are you buying a Spoon filter?
Spoon runs that setup becuase they are required by their race class to run the stock intake.
It has been proven that the larger the volume around the intake will increase the vacume, thus yeilding more performace. Hence Mugen and Comptech.
dpine
Sep 9, 2008 08:29 AM
98tegfreak
Sep 5, 2007 02:50 PM
Iomega01
Aug 9, 2005 12:51 PM
Chris Sawatsky
Mar 3, 2005 01:17 PM
dip-set
Mar 5, 2003 10:53 AM
