engine question
Old Nov 13, 2003 | 10:32 PM
sutekidane's Avatar
Default engine question
after reading the haynes manual, i think there's something wrong with my engine.
someone said i have an ex engine block and lx head (something like that).
is it hard to convert it to an ex head and hookup vtec? thanks.
Old Nov 14, 2003 | 12:35 AM
eL's Avatar
eL
Im guessing you're right... the b1 is an ex... which should have a vtec head... i dont see one on urs . uh why did someone do that?
Old Nov 14, 2003 | 09:56 AM
ramoneguru's Avatar
Default Re: (eL)
Hmmm well it could just be the valve cover. You could check under the cover to c if your head has the mid rocker arm and that the cam has that mid lobe. Since you have the Hayes manuel i believe it'll tell you the how-to on that....... Was there any work done on the car b4 you purchased it?? Was it a used car?? Private purchase or from the dealer?? Also, can you hear the Vtec "kick in" when you are at high rpm's (high being like 5500-7000)??
Old Nov 14, 2003 | 10:27 AM
crableg85's Avatar
Default Re: engine question (sutekidane)
hmm thats strange and a bummer man
Old Nov 14, 2003 | 10:42 AM
Globalundrground's Avatar
Default Re: engine question (crableg85)
Just look to see if you have a VTEC Solenoid or not..
Old Nov 14, 2003 | 10:49 AM
97F22B2's Avatar
Default Re: engine question (Globalundrground)
as posted an AccordinglyDone, you got fooked man. The Accord wiht the plugs in the back is th F22b2 head non VTEC and B1 is plugs up front. So the previuos owner most definantly screwed you. But you should be ok as long as you dont throw a VTEC code.
Old Nov 14, 2003 | 03:55 PM
Steve04SVT's Avatar
Default Re: (ramoneguru)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramoneguru &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm well it could just be the valve cover. You could check under the cover to c if your head has the mid rocker arm and that the cam has that mid lobe. Since you have the Hayes manuel i believe it'll tell you the how-to on that....... Was there any work done on the car b4 you purchased it?? Was it a used car?? Private purchase or from the dealer?? Also, can you hear the Vtec "kick in" when you are at high rpm's (high being like 5500-7000)??</TD></TR></TABLE>
Valve covers are different and cannot be swapped.
Old Nov 15, 2003 | 08:18 AM
sutekidane's Avatar
can you tell me where the vtec solenoid is located at?
the manual isn't that helpful at the moment.
thanks
Old Nov 15, 2003 | 08:37 AM
Steve04SVT's Avatar
On the passenger side of the valve cover. From the looks of it, there isn't one there. Non-Vtec and Vtec heads are different. There's no way to put a non-Vtec valve cover on a Vtec head, or vice versa.
r.etheridge
Honda Civic (2001 - 2005)
Apr 1, 2013 02:08 AM
EJ8_Enthusiast
35
Aug 15, 2008 02:10 PM
mortificationrock
10
Apr 10, 2007 09:25 PM
iblandford
18
Jul 10, 2006 11:13 PM
2ndGenREX
22
Apr 19, 2005 02:42 PM
