HID woes!
Old Nov 13, 2003 | 03:58 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default HID woes!
Well I have a 99 Mazda 626
There is something wrong with my hid kit
I have some misterjung hids
i bought it and hooked it up!
only one side lights up
the other drivers side doesn't light up
i know it works
what can be the problem
too many watts and i need to beef up the fuses?
Old Nov 13, 2003 | 04:06 PM
sloppy_seconds's Avatar
Banned
Default Re: HID woes! (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">Well I have a 99 Mazda 626
i know it works
there's your problem
the fuses shouldn't have to be "beefed" up, but i've heard of people upgrading to 20A fuses
Old Nov 13, 2003 | 04:08 PM
^jefs0ng's Avatar
Banned
Is misterjung a h-t memer? hid company? Sounds like a wack company name if you ask me.. like what everyone says about jdmsh!t..
Old Nov 13, 2003 | 04:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HID woes! (slowasscx)
You have to upgrade the fuses because the ballasts draw more power than stock for the first couple of seconds on initial start-up. Try turning them on while the car is running, usually there's no problem then.
But yeah misterjung HID's are generally crap.
Old Nov 13, 2003 | 04:54 PM
ebelp's Avatar
Default Re: HID woes! (PatrickGSR94)
I can't believe people are still buying misterjung's kits. Truly pathetic. If upgrading the fuses doesn't work, you'll have to try swapping the bulbs and/or swapping the ballasts. This way you'll be able to pinpoint where the problem is originating.
Old Nov 13, 2003 | 04:55 PM
junglistgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">I have some misterjung hids
theres your problem right there!
misterjung
Old Nov 13, 2003 | 04:57 PM
IntEGNYC's Avatar
Default Re: HID woes! (junglistgsr)
if you blew the headlight fuse, wouldnt both headlamps not ignite on your hid?
Old Nov 13, 2003 | 05:08 PM
Community Builder
Default Re: HID woes! (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">if you blew the headlight fuse, wouldnt both headlamps not ignite on your hid?</TD></TR></TABLE>
Each headlight has its own fuse.
Old Nov 13, 2003 | 07:11 PM
MugenHonda's Avatar
yeah i did
i figured it out
i need to purchase some relays so that i will always have a direct connection to the battery
thanks for the help
how are his hids crap?
they're hella
Old Nov 13, 2003 | 07:18 PM
MugenHonda's Avatar
And no you don't beef up fuses, unless you do your entire wiring, because if you beef up the fuses, and keep your stock wiring, it might be just too much and melt your entire lighting wiring system!
Old Nov 13, 2003 | 08:59 PM
Benbuilt4u's Avatar
i know it works
i know of 5 people who got those and just swap out to a 20 amp fuse. they only needed the extra power for the starup anyway
Old Nov 13, 2003 | 10:14 PM
iam7head's Avatar
Default Re: HID woes! (Benbuilt4u)
it's a electrical chassis ground car..
you dont put a 20amp fuse in it because 15amp blows, it blows for a reason, if you put a bigger fuse, now it's gonna burn the hid or what every component on it instead fo the safely feature-the fuse.
Old Nov 13, 2003 | 10:49 PM
Slain's Avatar
The reason why mr junk is junk is he uses broke *** quality capsules. They maybe be hella ballast but the capsules he uses are known to **** on you in a few months. only capsules i'd use are philips or osram 4100k-4300k anything above is garbage
DC2 Maggio
Honda Civic (2001 - 2005)
Feb 16, 2009 04:48 PM
r0c5t4r
Mar 28, 2004 03:21 AM
SHystrdyGSRtdy
Jun 15, 2003 08:42 PM
TypeRvtec18
Jan 21, 2003 08:19 PM
