What does a VTEC solenoid do?????
Old Nov 13, 2003 | 09:38 AM
AL ASPIRATED's Avatar
Default What does a VTEC solenoid do?????
just wondering what does it exactly do, and how it works. THANKS
Old Nov 13, 2003 | 11:03 AM
bruthaboost's Avatar
Default Re: What does a VTEC solenoid do????? (JDMTyPeRHaTcH)
It opens up a passage way for your oil to flow and push a plunger in your vtec assembly. Once the plunger is pushed down, oil pressure can "flow" into the rocker arm bars. The bars have holes that align with oil passages on the rocker arms. Within the rocker arms are dowels. As oil pressure flows in the rocker arm bars, into the rocker arms and then to the dowels, the rocker arms are "locked" together and thus you are on the high cam. You are now in almighty vtec
HTH
Old Nov 13, 2003 | 01:24 PM
Default Re: What does a VTEC solenoid do????? (bruthaboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost &raquo;</TD></TR><TR><TD CLASS="quote">It opens up a passage way for your oil to flow and push a plunger in your vtec assembly. Once the plunger is pushed down, oil pressure can "flow" into the rocker arm bars. The bars have holes that align with oil passages on the rocker arms. Within the rocker arms are dowels. As oil pressure flows in the rocker arm bars, into the rocker arms and then to the dowels, the rocker arms are "locked" together and thus you are on the high cam. You are now in almighty vtec
HTH</TD></TR></TABLE>
thanks man, now im a vtec nerd
Old Nov 13, 2003 | 02:20 PM
PHiZ's Avatar
http://auto.howstuffworks.com/camshaft.htm
http://auto.howstuffworks.com/question229.htm
Read them in the order presented.
-PHiZ
Old Apr 18, 2015 | 03:29 PM
TXaggie's Avatar
Found this helpful as well. Thanks.
tuan...
May 7, 2008 12:09 PM
s1ngle
May 6, 2005 06:50 PM
kerby116
Mar 11, 2004 01:06 PM
HybriDNA
Feb 23, 2004 07:10 PM
WICKED2
May 2, 2002 07:23 PM
