Chosing a tire size to match spedometer.
Old Nov 13, 2003 | 09:01 AM
631 Teggy's Avatar
Default Chosing a tire size to match spedometer.
Okay, I need someone who knows from personal exp.
I got new rims for my teg, they are 15x6.5, the stock rims are 15x6...
I need to pick tires for the new rims that will be close to even so the spedometer doesn't need to be re-calibrated...
Stock: 195/55 @ 15x6
New: ???/50 @ 15x6.5
I'll be getting azenis, so should i get 215, or 205?
PLEASE HELP!!!
Old Nov 13, 2003 | 10:27 AM
Buzzbomb's Avatar
Default Re: Chosing a tire size to match spedometer. (631 Teggy)
The 215/50 will match the sidewall height closer to the stock sidewall height.
195/55=107.25mm
215/50=107.5mm
Old Nov 13, 2003 | 11:17 AM
631 Teggy's Avatar
Default Re: Chosing a tire size to match spedometer. (Buzzbomb)
I know - but thats only if if it's on the same size rim...
This is a problem cuz i'm going from a 6inch to a 6.5 inch wide rim...
Thanx for the response tho
Old Nov 13, 2003 | 11:30 AM
JimBlake's Avatar
It's not the width... You want to match (close) the overall diameter of the tread. TireRack.com has that listed for most of their tires. I wanna say something like 205/45-16 or 205/50-16 but I'm not sure which.
Doh! I thought you were asking about 16" rims...
Modified by JimBlake at 5:27 PM 11/13/2003
Old Nov 13, 2003 | 11:52 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Chosing a tire size to match spedometer. (JimBlake)
http://www.miata.net/garage/tirecalc.html
The width of the wheel will affect the overall diameter, but not enough to really worry about
215/50/15 matches the diameter perfectly
Stan
Old Nov 13, 2003 | 12:18 PM
rapid_roy's Avatar
205/50R15 is what you want. A 205 is a closer fit on a 6.5" wide rim that on a 6" wide rim, so that is as close as you are going to get.
stock diameter is 23.4" and a 205 is 23.1".
Check the diameters on this page:
http://www.kumhousa.com/Produc...D=712
or better yet, for the particular tire you intend on buying.
Cheers,
Roy
Old Nov 13, 2003 | 01:36 PM
631 Teggy's Avatar
90crxsi - yes i know that site, and thanx, but like i said, it's a different width, and it does make a difference, thank you all the same...
rapid_roy - Thank you, that helped me a lot!
twentyhurtz
Nov 25, 2008 05:02 AM
janz3n
Apr 5, 2006 08:44 AM
cilvia
Aug 11, 2005 08:01 PM
JDMRice
Jun 18, 2005 07:27 AM
zither
Jun 22, 2002 08:14 AM
