how do i check breaks in the circuit with an ohmeter??
Old Nov 13, 2003 | 07:52 AM
dingusjt's Avatar
Default how do i check breaks in the circuit with an ohmeter??
i tried posting this in ef forum but it seems as though no one can help..anyway i'm throwing code 14 on my pm5 which is my EACV, well i replaced and i'm still throwing the code...
so how do i go about testing each wire for functionality?, its only a 2 wire sensor one black/yellow and the other blue/yellow
Old Nov 13, 2003 | 08:41 AM
JimBlake's Avatar
Default Re: how do i check breaks in the circuit with an ohmeter?? (dingusjt)
Disconnect both ends of the wiring, put your ohm-meter across from the wire to ground. It should read OL or infinite or something like that. No continuity.
Then ground one end of the wire, maybe you need to make up a jumper wire to reach a good ground. Then check your ohm-meter from the other end to ground. NOW it should have good continuity. Like a couple ohms or so.
Make sure you understand the wiring drawing, too. Sometimes a wire will branch somewhere in the middle, so you'll have to disconnect all 3 ends. For example the signal wire from the VSS branches - it goes to both the ECU and the cluster.
90_EX_Civic
Mar 21, 2009 07:59 PM
aznryd3r
Nov 24, 2006 10:05 AM
dingusjt
Nov 13, 2003 10:18 AM
DsMWookie
Jan 31, 2003 08:31 AM
T25 civic
Oct 6, 2002 02:11 PM
