how do i check my EACV sensor for wire breaks??
ok i replaced my EACV and i'm still getting code 14 so how do i got about checking the wires with an ohmeter to see if there are any breaks...please i need some simple instructions..thanks.
find the ECU pinout.. see which one is the EACV wire.. turn ur multimeter to ohms.. put a lead on the connector to the EACV and another lead to the ECU pin.. if the is ohm's anything.. that means there is continuity.. so the wire is good.. don't worry some how my wire has a break in it too.. i ran a new wire straight from the EACV to the ECU and it works fine now.. i don't know how just that one wire went bad but it did???
