sprayed water in engine bay now car won't start???
Old Sep 10, 2001 | 01:13 PM
TKBLAZER's Avatar
Default sprayed water in engine bay now car won't start???
i was degreasing my engine bay yesterday and i bagged up my filter and distributor. After i was done washing my car it started up fine i drove it around for a few minutes, then all of a sudden my car starts to lose power and then shuts off completely. So far i checked my plugs, wires, pulled the distributor cap off and check the rotor. I have no idea wat to check or wats wrong...has anyone had the same thing happen before?
Old Sep 10, 2001 | 01:18 PM
GTEater's Avatar
Default Re: sprayed water in engine bay now car won't start??? (TKBLAZER)
take off the intake and see if the inside is wet......maybe you hydro-locked?.......small possibility, but worth a try
Old Sep 10, 2001 | 01:22 PM
Jesse H's Avatar
Default Re: sprayed water in engine bay now car won't start??? (GTEater)
check for water in plugs, and distributor...i'd bet a coke that's what it is
Old Sep 10, 2001 | 01:25 PM
WOTTEG's Avatar
Default Re: sprayed water in engine bay now car won't start??? (Jesse H)
Sounds more like you are hotwiring some electrical connections. Inspect your wiring harness, and dry out what needs it. Also check the fuse box, etc.
No chance of Hydro-locking methinks.
Karl
Old Sep 10, 2001 | 01:29 PM
MugenFormula1's Avatar
Default Re: sprayed water in engine bay now car won't start??? (WOTTEG)
it`s not hydrolocked.
Old Sep 10, 2001 | 01:30 PM
Surftek07's Avatar
New User
If it turns over it got to be your distributor cap I did the same thing.
Old Sep 10, 2001 | 01:33 PM
KL's Avatar
KL
New User
Default Re: sprayed water in engine bay now car won't start??? (Surftek07)
Make sure you check the cavity the spark plugs are installed to make sure there is no accumulation of water, I did this to myself once......
If your car is a GSR, it's most likely the plug cavity towards the passenger side as the plastic VTEC cover opens up to allow the plug wires to come in.
Old Sep 10, 2001 | 02:30 PM
Alexander's Avatar
Default Re: sprayed water in engine bay now car won't start??? (KL)
can anyone describe/post pictures of exactly what you're supposed to cover if you're going to spray down your engine and scrub her clean? distributor cap, plugs etc? thanks.
Alex
Old Sep 10, 2001 | 04:00 PM
Dee's Avatar
Dee
Default Re: sprayed water in engine bay now car won't start??? (AVD23)
Check your alternator! I fried the one on my old CRX SiR by mistake 4 years ago while cleaning the engine bay with citrus cleaner. Check for spark. Check for a loose connection at the dist. Check for blown fuses...
Old Sep 10, 2001 | 05:21 PM
B18C-RnVA's Avatar
New User
Default Re: sprayed water in engine bay now car won't start??? (drealgsr)
Yeah it has to be the alternator, cause when i was cleaning out my engine bay, my mind must been somewhere else, cause i almost sprayed my bay with out covering up my alternator. i cover it up with a couple of towels, and right when im done i start the car up and let it idle for a song or too.
Old Sep 10, 2001 | 08:35 PM
TKBLAZER's Avatar
Default Re: sprayed water in engine bay now car won't start??? (B18C-RnVA)
yea i'm afraid it just may be the alternator...i checked the plugs, fuses, distributor is bone dry....there is just no spark. so i gotta find out if its the distributor or alternator...
Old Sep 10, 2001 | 08:39 PM
MiraiZ's Avatar
Plugs and distributor dude!! let the car dry out...next time spray it with mist with the engine running...stay away from intake, oil dip stick, and anything electrical...just the block and head cover should do...
Old Sep 12, 2001 | 03:31 PM
TKBLAZER's Avatar
Default Re: sprayed water in engine bay now car won't start??? (MiraiZ)
well its been a few days and car still won't start...anyone know how to tell if the ICM is working or not? and how much to replace it or even how much a distributor cost to replace.
Old Sep 12, 2001 | 03:33 PM
TKBLAZER's Avatar
its been a few days and my car still won't start. does anyone have any idea to check if the ICM in the distributor is working or not. Also how much do replacement distributors go for?
Old Sep 13, 2001 | 04:30 AM
yaksplat's Avatar
you can find a wide range of prices if you call around
when i did mine it was 20 for the rotor and 20 for the cap
I did find cheaper prices, but they were all special orders and i didnn't fele like waiting
open it up and look at it before you go get a new one
the conductive part of the rotor on mine was rusty
Old Sep 15, 2001 | 09:11 PM
TKBLAZER's Avatar
Default Re: sprayed water in engine bay now car won't start??? (yaksplat)
thanx for the help guys...the problem ended up being a bad ignition coil....cost me $40 for the part. I'm just glad i didn't have to replace the whole distributor.
Old Sep 16, 2001 | 07:16 AM
1fastGSR's Avatar
New User
your distributor or plugs got wet!
activar
10
May 22, 2011 06:15 AM
lickety_britches
Jul 27, 2010 08:08 AM
DIS-1
12
Jun 20, 2007 01:40 PM
Shadowed Reaper
25
Dec 15, 2005 09:53 AM
Comptech98GSR
Jan 25, 2002 05:05 PM
