gsr b18 into cx hatchback
Old Nov 12, 2003 | 08:49 PM
prennro's Avatar
Default gsr b18 into cx hatchback
3 Major Questions:
1. Im not getting VTEC to kick in...could this be due to the check engine light or lack of wiring.
2. Will O2 sensor turn off check engine light
3. Do I have to wire in Knock Sensor, if so How do I do so???
Thanks for any input
Old Nov 13, 2003 | 04:28 AM
VTECVillain's Avatar
Default Re: gsr b18 into cx hatchback (prennro)
It's obvious that your check engine light is on so have you jumped the service connector to see what codes it's showing? If you are using a P72 or any other ECU that has a knock sensor function then YES you need to wire it up or you will have a constant CEL.
If you dropped the motor in and didn't wire anything up, then you'll need to wire up the VTEC solenoid, VTEC pressure switch, Knock sensor, IAB and convert to a 4 wire O2 sensor. Don't cut corners, do it right!
sdnewaccord
Oct 16, 2011 04:01 PM
xtremehawn
10
Dec 3, 2007 12:40 PM
slo4door
10
Apr 22, 2003 08:18 AM
lonefuzzy79
Jan 19, 2003 04:29 PM
PhuckinHondas
Sep 18, 2002 09:37 PM
