overrevved motor
Old Nov 12, 2003 | 08:33 PM
WhOIZiT's Avatar
Default overrevved motor
i overrevved my motor the other day past 9k and i have a rev limiter by 8. it scared the shlt out of me and im wondering if i f* my motor up b/c it seems to have lowered its idle to 100 rpm less. i notice it b/c i know my car well. any suggestions to wat i may f'd up, im also gonna check the codes b/c the check light came on after i restarted my car.
Old Nov 12, 2003 | 08:37 PM
LSTEG96's Avatar
Default Re: overrevved motor (WhOIZiT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhOIZiT &raquo;</TD></TR><TR><TD CLASS="quote">i overrevved my motor the other day past 9k and i have a rev limiter by 8. it scared the shlt out of me and im wondering if i f* my motor up b/c it seems to have lowered its idle to 100 rpm less. i notice it b/c i know my car well. any suggestions to wat i may f'd up, im also gonna check the codes b/c the check light came on after i restarted my car. </TD></TR></TABLE>
u may know ur car well... but not well enough to shift correctly!! u prolly bent a valve yO!
Old Nov 12, 2003 | 08:39 PM
631 Teggy's Avatar
ya you probably fucked up your car
There may have been piston to valve contact, in which case your valvetrain is probably fucked... may have thrown a rod, but if the engine stars then probably not... Valves might be warped, and valtrain may be demolished... i wish you luck...
DO NOT DRIVE THE CAR
Old Nov 12, 2003 | 08:51 PM
integraL's Avatar
Default Re: overrevved motor (631 Teggy)
yep classic valve bender! go and check the codes and compression test
Old Nov 12, 2003 | 09:28 PM
furious94ls's Avatar
Default Re: overrevved motor (integraL)
Do the valves sound louder than usual. Rough idle? Sputtering exhaust? If so its a valve or more.
Old Nov 14, 2003 | 12:44 AM
WhOIZiT's Avatar
damn damn crap crap. yeh that suks ima check it out asap. kinda suks..thanx
Old Nov 14, 2003 | 05:54 AM
1hotintegra's Avatar
Default Re: (WhOIZiT)
yea it does suck... same thing that happened to me but it gives u good reason to build up ur top end
Old Nov 14, 2003 | 07:22 AM
player2z's Avatar
a valve is bent possibly ur compression dropped as well
250cc_SuperKart
Sep 13, 2015 08:42 AM
Eyal 951
Dec 24, 2007 09:35 PM
defkid999
Oct 7, 2007 11:49 PM
mario82686
Apr 14, 2004 03:40 PM
B20vtec86crx
17
Feb 3, 2004 06:04 PM
