EX and DX automatic transmissions: interchangeable in EKs?
Old Nov 12, 2003 | 11:04 AM
Campee's Avatar
Default EX and DX automatic transmissions: interchangeable in EKs?
Will the automatic transmission from an EX work in a DX if they're both EK?
Old Nov 12, 2003 | 11:06 AM
LSVTECoupe's Avatar
Default Re: EX and DX automatic transmissions: interchangeable in EKs? (Campee)
yes
Old Nov 12, 2003 | 11:15 AM
Campee's Avatar
Default Re: EX and DX automatic transmissions: interchangeable in EKs? (LSVTECoupe)
Is there any difference between the two? Different gearing, etc? Is an EX tranny stronger?
Old Nov 12, 2003 | 12:25 PM
Jester88Si's Avatar
Can someone anwser his question? I'm curious myself because my ex AT is dead and i cant seem to find an EX replacement so i wanna know if the DX AT is the same thing?
Old Nov 12, 2003 | 12:43 PM
Campee's Avatar
Default Re: (Jester88Si)
What's going on with your transmission? How did it die?
Old Nov 12, 2003 | 01:05 PM
Jester88Si's Avatar
Default Re: (Campee)
my bro bottomed out the car (94 civic ex sedan) and after that the tranny would just go neutral after it was warmed up but when you shut off the car and turn it back on it'll work for a few min then the same thing.....tranny is already pulled though just waiting for a replacement and i dont wanna put a dx tranny in there if its too weak or it has different gearing that will mess with the d16z6
Old Nov 12, 2003 | 01:06 PM
2000blackgsr's Avatar
DX tranny has longer gears than EX. EX is the way to go, but do a manual conv if you can
Old Nov 12, 2003 | 01:28 PM
Smith Wise's Avatar
Default Re: (96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96coupe &raquo;</TD></TR><TR><TD CLASS="quote">DX tranny has longer gears than EX. EX is the way to go, but do a manual conv if you can </TD></TR></TABLE>
not worth it IMHO. if you want a a 5spd vehicle buy a 5spd vehicle
Old Nov 12, 2003 | 01:59 PM
Campee's Avatar
Default Re: (Jswpstdoff)
Agreed. Will the longer gears have an adverse affect on a DX motor? Is the gearing made for a higher output motor? Will it rev the motor too high or something?
Old Nov 12, 2003 | 02:24 PM
Jester88Si's Avatar
Finally a clear answer so the EX trans has shorter gears for the vtec then eh? and the DX has longer gears cause its pos right? so is that the only difference?
Old Nov 13, 2003 | 12:01 PM
Campee's Avatar
Bump
Old Nov 13, 2003 | 03:01 PM
Jester88Si's Avatar
heh heh it doesnt matter now I was able to find a ex auto in a 2dr coupe at some salvage place had them pull it picked it up today its g00d
Old Nov 13, 2003 | 06:53 PM
Campee's Avatar
How much did you pay?
Old Nov 13, 2003 | 08:41 PM
Jester88Si's Avatar
$270.63 122k miles ....some salvage yard here in dallas
Old Nov 13, 2003 | 08:46 PM
Jester88Si's Avatar
also my 94 civic ex is my cruising car thats why its auto the crx is for everything else and its 5spd
Old Nov 14, 2003 | 10:22 PM
Campee's Avatar
Damn, 122K? Isn't it going to blow up soon? :/
Herbie
Nov 18, 2014 09:57 AM
fryman
27
Nov 23, 2009 03:55 PM
blvdman
10
Jan 7, 2006 10:22 PM
ekcivic9
Sep 18, 2005 11:04 AM
turbod16y7vtec
Sep 27, 2002 08:09 PM
