Piston to valve clearances with CTR pistons and Skunk2 cams
Old Sep 10, 2001 | 09:50 AM
FAST94GSR's Avatar
New User
Default Piston to valve clearances with CTR pistons and Skunk2 cams
Does anybody have this combination by any chance? Also my head is milled .020.
I got a fresh type R block that is just begging for higher compression pistons to go in it.
I'm just wondering if I would have any issues regarding this combination with my setup.
thanks in advance.
Old Sep 10, 2001 | 12:34 PM
FAST94GSR's Avatar
New User
Default Re: Piston to valve clearances with CTR pistons and Skunk2 cams (FAST94GSR)
ttt
Old Sep 10, 2001 | 08:34 PM
t's Avatar
t
I dont have the combo but you should have no clearance problems
Old Sep 11, 2001 | 04:02 AM
D's Avatar
D
"ooooh, i'm jeff's new C5 block..... i really really want high compression pistons...."
dude, could always clay the assembly before you swap blocks..... if you're concerned.
D
Old Sep 13, 2001 | 02:53 PM
fastbrakes's Avatar
You should have at least 0.040 piston to valve clearance for the intakes and 0.060 for the exhaust. Clay checking is the only way to tell, especially with a cut head...
Old Sep 18, 2001 | 01:15 PM
GM2000ITR's Avatar
New User
I have that combo in my LS/VTEC, but I have a non-milled head. No problems at all. I think your budy is right: clay the assembly, it may be the only way to tell w/ a milled head. Off the record though, I think you should be O.K. -Later!
Old Sep 18, 2001 | 04:48 PM
FAST94GSR's Avatar
New User
Default Re: Piston to valve clearances with CTR pistons and Skunk2 cams (GM2000ITR)
Hey what kind of power are u making? Im sure your making 200 easy.
Old Sep 19, 2001 | 05:58 AM
GM2000ITR's Avatar
New User
I haven't ben to the dyno yet, but I made 186whp/133 tq with CTR cams and USDM ITR exhaust manifold/cat. I now have the Skunk2 cams, DC JDM 4:1, and test pipe. I hope to at least be close to 200whp. We'll see!
Chance EG
Apr 6, 2020 11:27 AM
monster_c
Nov 26, 2011 12:23 AM
GSR_hatch936
Apr 13, 2010 01:14 PM
RicTRD
Sep 16, 2005 03:46 PM
Battle Cat
Apr 16, 2005 02:51 PM
