19 blinks from the pm5?
Old Nov 11, 2003 | 03:00 PM
89a6T's Avatar
Default 19 blinks from the pm5?
Old Nov 11, 2003 | 03:14 PM
89a6T's Avatar
i found out what the code is
0 - Faulty ECU
1 - Oxygen Content
3 - Manifold Absolute Pressure
4 - Crank Angle
5 - Manifold Absolute Pressure
6 - Coolent Temperature
7 - Throttle Angle
8 - TDC Position
9 - #1 Cyl. Position (HF and Si Models)
10 - Intake Air Temperature
12 - Exhaust and Gas Recirculation System
13 - Atmospheric Pressure
14 - Electric Air Control
15 - Ignition Output Signal
16 - Fuel Injector
17 - Vehicle Speed Sensor
19 - Lock-up Control Solenoid Valve
20 - Electric Load
but how do i fix/what does it do?
EG8R's Avatar
Default Re: 19 blinks from the pm5? (89a6T)
19 - Lockup Control Solenoid Valve (A/T)
Old Nov 11, 2003 | 03:15 PM
EG8R's Avatar
Default Re: 19 blinks from the pm5? (skelly ed6)
https://honda-tech.com/zerothread?id=468260
Old Nov 11, 2003 | 03:33 PM
89a6T's Avatar
so that would mean i got the wrong ecu. ill try and convert it to manual, i saw how to do somewhere, then see what it does.
Old Nov 11, 2003 | 03:34 PM
89a6T's Avatar
i think im getting #1 to but i not sure. how would i check/ correct if im getting code 1
Old Nov 11, 2003 | 04:12 PM
Patch's Avatar
Default Re: (89a6T)
Code 1 is kinda weird, it blinks one short blink one time every 2 or 3 seconds. All other codes have a long blink and a pause, or short blinks with a very short pause.
Old Nov 12, 2003 | 04:56 AM
89a6T's Avatar
car is still not running...need help!
ach2291
Feb 10, 2013 09:07 AM
integra_freak96
Oct 16, 2007 11:09 AM
93sleeper
Feb 20, 2005 08:03 PM
THE FUCATYPR HATCH
Jan 27, 2005 09:17 PM
shorti
Jan 28, 2003 09:47 PM
