Code 4-crank angle sensor. and code 22-vtec pressure valve
Old Feb 10, 2013 | 07:44 AM
ach2291's Avatar
Default Code 4-crank angle sensor. and code 22-vtec pressure valve
okay, well i had a post prior because i thought it may have been the egr.
here is the info. i had a code 0 but i fixed some loose wires and my ecu is fine.
now i have the real problem. Code 4- i know how to check the crank angle sensor i just don't know what the ohm should be at as my manual lacks the info.
as for the vtec pressure value. i don't even know where that is.
any advice would be greatly appreciated and take. thanks
Old Feb 10, 2013 | 09:07 AM
ach2291's Avatar
Default Re: Code 4-crank angle sensor. and code 22-vtec pressure valve
scratch that. the vtec pressure valve was also hooked up wrong on the ecu. hooked it up and no more bogging or anything engine runs smooth but now im getting a code 23 knock sensor.didn't come on until i got down the road. what could be the problem?
Ek4 life
Oct 4, 2012 09:30 AM
happyabortion
May 13, 2008 04:18 PM
civicx
Oct 4, 2005 03:12 PM
kholmes
Mar 16, 2005 07:41 AM
THE FUCATYPR HATCH
Jan 27, 2005 09:17 PM
