Adjusting Clutch pedel on a hydro car
Old Nov 11, 2003 | 02:22 PM
jdmcivicferio's Avatar
Default Adjusting Clutch pedel on a hydro car
I have a 92-95 civic, with a heavy duty clutch, a springless doul diaphram. And it is really hard to push down on and I keep on breaking clutch master cylinders and release bearings. Is there a proper way to calibrate the clutch pedal so I will stop breaking things? thanks
Old Nov 11, 2003 | 03:07 PM
prestonpark's Avatar
Default Re: Adjusting Clutch pedel on a hydro car (jdmcivicferio)
look at the clutch pedal u see a screw if u loos that nut and tight that screw more it will push ur cluch pedal lower
Old Nov 11, 2003 | 03:14 PM
Default Re: Adjusting Clutch pedel on a hydro car (civic2003)
ya but is there a proper way to adjust so you are not fighting against the clutch fork?
Old Nov 11, 2003 | 03:19 PM
nsxmatt's Avatar
Unless it has air in the lines and you need to bleed it, it's non-adjustable I believe.
Old Nov 11, 2003 | 09:30 PM
Default Re: Adjusting Clutch pedel on a hydro car (nsxmatt)
no it's adjustable, I just don't no how to calibrate it properly...
Old Nov 11, 2003 | 10:41 PM
GRAVEDIGGER's Avatar
you can only adjust pedal free play and bleed the line. if you look up above the pedal on the clutch there is 2 bolts that you adjust pedal play with .Adjust so there is about a inch or so of free play .if its to tight your clutch will slip in high RPMs.hope it helps.
Old Nov 12, 2003 | 06:02 AM
The Internet Tough Guy's Avatar
Default Re: Adjusting Clutch pedel on a hydro car (GRAVEDIGGER)
sounds to me like you may need to fix a little more than just adjusting the pedal...
Stonage07
Mar 6, 2017 11:48 AM
Jdmkdmkid
May 5, 2013 06:45 PM
Kyle244R948
Nov 26, 2008 01:25 AM
redman223
Jul 13, 2007 07:19 PM
MrSmith
Sep 28, 2001 08:30 PM
