Wheel bearing
Okay as I was putting a new axle on my car today (replacing the LS axle that I used to get home on) I was turning my rotor and I noticed a weird sound. So I took my caliper off and stuff to make sure that was not making the noise, and come to find out, it sounds like I have a bad bearing. I had a problem coming home from Vegas, my car was pulling to the left pretty hard, but after we stopped and did some things, I turned around a few times in my car, and it stopped, so thankfully we made it home. Well here is what I wanna know, are the Si,GSR,LS, Type R....front brearings all the same?? cause there is a honda dealer like 70 miles from here, and if the Si wheel bearing will work, then I will just use one of them. So please help if you can, thanks
are you sure you didnt manage to mangle the backing plate so that its rubbing against the rotor when getting the new axle in the hub?
RJ - who's done this every time he's pulled an axle....
yeah, i checked and made sure nothing was rubbbing it, but I went to ordered a new hub assembly today, cause thats how they come, you cant just buy the bearing i guess, but i havnet torn it apart, so i dont know exactly what it would be exactly :-)
jdmcivicracer89
Nov 10, 2010 09:59 PM
