head weld good or bad?
there are numerous reasons it could have been welded. but as long as it does not affect the performance of the head, then u have nothing to worry about.... i had to re-weld a spot on my engine block no worries, just go with it
They welded it because that plug was leaking. It is not uncommon to do. It can crack if done poorly. But if it has been running like that w/o water(coolant) and oil mixing you are probably o.k.
