transfer internals from one block to another...
Old Nov 11, 2003 | 09:44 AM
See Are X's Avatar
Default transfer internals from one block to another...
I need to transfer the bottom end(crank, rods, pistons) from a block that has rusted cylinder walls to another block...can I just drop the crank with the rods/pistons attached? and then swap EVERYTHING to the new block? everything = crank caps, crank bearings, front/rear seals, thrust bearing
See Are X's Avatar
Default Re: transfer internals from one block to another... (See Are X)
I would buy new bearings and stuff, but this motor is just a temporary motor...
Old Nov 11, 2003 | 10:50 AM
Benny Hinn's Avatar
It will be some more work than you think if you try to swap over the main caps.
JDM Lyfestyle
May 4, 2009 08:30 PM
TcUiRvBiOc
May 16, 2007 01:29 PM
salt
Mar 2, 2006 02:56 PM
metal-x
Mar 4, 2003 12:06 PM
