is it safe to run a 2" exhust with turbo?
Old Sep 9, 2001 | 08:23 PM
DIRep972's Avatar
Smarter than you
Default is it safe to run a 2" exhust with turbo?
my turbo will be goin on soon, and i was plannin on goin with the 3" thermal, but now that i look at my funds its lookin like that exhuast will have to come at a later date...
Right now i have a DC sports cat back.. not sure the size but im pretty sure its 2" or a lil more.. if i run a test pipe to this exhuast will i just loose power, or will it cause alot of backpressure and create alot of heat?
it will just be tempory till i save up for the thermal, maybe 1-2 months at .5bar on a LS..
Old Sep 10, 2001 | 08:04 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: is it safe to run a 2" exhust with turbo? (DIRep972)
you should be alright with any aftermarket exhaust. just keep the boost from going too high. you will want a test pipe or race cat in there also.
Old Sep 11, 2001 | 10:53 AM
DIRep972's Avatar
Smarter than you
Default Re: is it safe to run a 2" exhust with turbo? (ho focker)
im thinken about just runnin lower boost till i can get a bigger exhaust
coquieg6
Jul 7, 2009 03:26 PM
KRWTEK1
Feb 5, 2007 07:42 PM
firstclassjdm
Apr 11, 2005 10:00 PM
D-t
Nov 25, 2004 08:45 PM
CWBETB
May 18, 2004 06:24 PM
