code 4,16,17,43 engine stutter at 5k rpms HELP!!!!
Old Nov 10, 2003 | 05:00 PM
b16a1sirhb's Avatar
Default code 4,16,17,43 engine stutter at 5k rpms HELP!!!!
As the title says the car is a 90 std with a b16 running a pr4 with fields vtec controller. It doesn't matter if it is WOT or just criusin and i've tried very thing i can think of with no improvement. I'm thinking about just pulling the sub-harness and doing it again. any thoughts would be helpfull. Thank you...
Old Nov 10, 2003 | 05:26 PM
crxgator's Avatar
Default Re: code 4,16,17,43 engine stutter at 5k rpms HELP!!!! (b16a1sirhb)
4- crank angle sensor
16- Fuel injector
17- VSS (check your speedo cable)
43- Fuel Supply system (most likly a problem in the oxygen sensor circuit A)
time for some fun...download the helms and go from there...
Old Nov 10, 2003 | 07:20 PM
b16a1sirhb's Avatar
Man i know the codes, Thanks anyways, I've changed the injectors 3 times, changed the whole fuel supply, speedo works changed the 02 sencer. it's gotta be bunk *** wiring anyone else
Old Nov 10, 2003 | 08:17 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a1sirhb &raquo;</TD></TR><TR><TD CLASS="quote">As the title says the car is a 90 std with a b16 running a pr4 with fields vtec controller. It doesn't matter if it is WOT or just criusin and i've tried very thing i can think of with no improvement. I'm thinking about just pulling the sub-harness and doing it again. any thoughts would be helpfull. Thank you...</TD></TR></TABLE>
4- make sure the crank angle sensor and the other plug on the intake manifold forget what its called, but i belive it is a green clip goes one the drivers side of the intake manifold) aret mixed up. they are the same type plug try switching them
16/43- make sure your dpfi to mpfi wires to the fuel injecters are right.
17- make sure your cable that comes off the guage cluster and into the enigine bay is clipped into the tranny...its a small round plug and it plugs right into the transmission.
edit- just read that you said the speedometer works. try resetting the ecu and see if it clears the code 17
SoHc94
Apr 28, 2007 12:21 AM
NA_DA
Jun 6, 2006 07:03 AM
JFG Kevin
May 18, 2006 03:58 PM
bossman032
Jun 30, 2003 04:30 PM
stockcrx
Feb 9, 2003 08:40 PM
