Where do you guys shift on your LS motor?????
Old Nov 9, 2003 | 08:15 PM
FLATOUTRACING's Avatar
Default Where do you guys shift on your LS motor?????
Just purchased a Integra race car with a LS motor. What RPM's do you guys shift at in the top three gears?
Regards,
J. Kofod
1996 Integra LS Grand Am Spec Car
Old Nov 9, 2003 | 08:24 PM
88civicHB703's Avatar
normal driving 3k, racing 6-6500rpm stock rev limits..
Old Nov 9, 2003 | 08:27 PM
The-LS's Avatar
Default Re: (88civicHB703)
another thread with this exact topic already,
https://honda-tech.com/zerothread?id=664615
Old Nov 9, 2003 | 09:53 PM
Newman's Avatar
New User
Default Re: Where do you guys shift on your LS motor????? (ITSRACER)
I hear that question all the time.... "what's the best RPMs to shift my motor at?"
My reponse, which is the same all the time.... "dyno your car, see where your max HP is at, that's your shift point."
There's no point to shift at 8000 if your motor doesn't make any power after 7400 rpms. Nor is there any point to shift early when racing if your car can make power higher. Can't get more simple than that.
Old Nov 9, 2003 | 10:04 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Where do you guys shift on your LS motor????? (Newman)
It would have probably been a good idea to do more research prior to buying a RACE car, but hey, its your money.
Good luck with the car.
Old Nov 9, 2003 | 10:23 PM
EdoMoto's Avatar
Good Question. I also have a LS race car i rev to 7300 RPM thats where it stops pulling. But also depends how your power band is. if the power drops off at 7000 RPM then there is no use in reving past 7200.
Old Nov 9, 2003 | 11:30 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">There's no point to shift at 8000 if your motor doesn't make any power after 7400 rpms. Nor is there any point to shift early when racing if your car can make power higher. Can't get more simple than that.</TD></TR></TABLE>
ok this has been covered. if you shift at 8k, as opposed to 7.4k, you will shift into 2nd gear at a higher rpm than shifting at 7400 rpms. and the higher rpms you are at in 2nd gear, you'll have access to more of your torque in that gear.
shift at 7400rpms - land on 5500
shift at 8000rpms - land on 6000
those numbers are guestimates. but i think you know what i mean
Old Nov 10, 2003 | 02:43 AM
StyleTEG's Avatar
Default Re: Where do you guys shift on your LS motor????? (integraL)
You don't necissarily want to land higher in the RPM band.
Using your numbers as examples...
If your powerband starts at 5,500 and dies off at 7,500 you are better off shifting at 7,500 rather than stretching it out to 8,000rpm to land in the middle of your powerband rather than the begining of it.
Old Nov 10, 2003 | 02:44 AM
91tegrals's Avatar
also dpends on wat mods you have doen to the motor like cam if you have aftermarkett cams that the redline will change so wat are youre mods...
Old Nov 10, 2003 | 06:14 AM
Thanks for the help folks. The LS engine is stock (without any emissions gear). We did dyno it and it looks pretty close to a stock graph with max hp made just 200 rpm's higher due to some chip tuning. The motor has different valve springs (titanium) to cope with contant high rpm operation.
Have not had a chance to test the car yet but was told to shift at 7000 rpm's to get the engine back in the middle of the rev band rather than at the bottom.
Just wanted some opinions. Many times people equate more noise (higher rpm's) with more power when in actuality they have less power.
Since I don't plan to take the car to the drag strip or do standing starts (not street legal) I was trying to see what most on this board thought from their experiences.
integra707, I have no familiarity with Acuras but did quite a bit of research on the car before buying it. Just wanted some opinion from LS owners.
Great board! Thanks for the info!
Regards,
Jon P. Kofod
http://www.flatoutracing.net
Old Nov 10, 2003 | 07:35 AM
Komsomol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSRACER &raquo;</TD></TR><TR><TD CLASS="quote">Just purchased a Integra race car with a LS motor. What RPM's do you guys shift at in the top three gears?
Regards,
J. Kofod
I've seen this car before.. Didnt someone from on here used to own it?
Old Nov 10, 2003 | 07:38 AM
Default Re: Where do you guys shift on your LS motor????? (8400RPMS)
This car was previously owned and raced by Nonnemaker Racing in Grand Am Cup. They ran three cars (all identical) and won the Grand Am Cup STII Championship with the car.
It's a GSR but with an LS motor.
Regards,
Jon
Old Nov 10, 2003 | 07:57 AM
Train's Avatar
you have a race car with a stock ls motor?? how did it win races? i mean, i'm sure it handles nice, but shouldn't a race car have power? correct me if i'm wrong.
Old Nov 10, 2003 | 07:58 AM
dom93hatch's Avatar
Odd.
Old Nov 10, 2003 | 08:03 AM
EdoMoto's Avatar
If it has titanium valve springs and is a GSR with LS motor. I dont think that this car is legal in ITS.
Sorry had to mention it.
Old Nov 10, 2003 | 08:06 AM
EdoMoto's Avatar
Default Re: Where do you guys shift on your LS motor????? (Train)
Not everyone needls lots of HP to go fast. Its 80% driver and 20%car.(this applies if you really know how to drive the wheels off the car. If you dont you better find a different hobby.
Default Re: Where do you guys shift on your LS motor????? (dom93hatch)
The car runs in Grand Am Cup STII class where the GSR and Type R motors are prohibited. Running the other two motors bumps you up a class.
I am replacing the LS motor with a GSR next season to run in SCCA.
The car is still pretty quick. Remember it's stripped and weighs only 2300 pounds.
It competed with Mazda Miatas, other Acura Integras, Mazda Proteges, and Chevy Cavalier Z-24's.
The motor makes just under 150 hp and has the exact same torque figure as a GSR.
Just to give you an idea a Type R motored Integra did a 1:44 at Mid Ohio race while this car did a 1:40. Only a 4 second difference between the two classes.
Regards,
Jon
Old Nov 10, 2003 | 02:32 PM
Komsomol's Avatar
Can u do anything sneaky like change the cam etc?
4 door beast
May 3, 2009 04:16 AM
Imprezor
Jul 28, 2008 08:57 PM
7rrivera7
Jan 25, 2007 06:28 PM
t . b o z
Jun 8, 2004 10:50 PM
