Chattering sound coming from tranny???
Old Nov 9, 2003 | 02:44 PM
blacksheep's Avatar
Default Chattering sound coming from tranny???
There is a soft chattering sound coming from my tranny when I am in gear and no throttle.. when I'm accelerating or just applying throttle to maintain speed there is no sound.. or if I'm in neutral there is no sound. I thought it was the passenger side axle but I changed that yesterday and that didn't cure it. My setup is 94 Integra LS, GS-R tranny w/ Cusco LSD, Clutch Specialties 6-puck clutch and lightened flywheel. The clutch and tranny were just installed about 5-6k miles ago. My friend told me the flywheel bolts may be loose.. and that makes sense to me. The tranny feels fine, and it still drives fine, but I don't want to drive it anymore til I find out what is causing this sound and fix it. I hate to pull the tranny off just to find out the flywheel bolts are tight.. any ideas??
Old Nov 9, 2003 | 03:27 PM
Miz101's Avatar
Default Re: Chattering sound coming from tranny??? (blacksheep)
Have you checked heat shield on cat. ?
Old Nov 9, 2003 | 07:18 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Chattering sound coming from tranny??? (Miz101)
Throw-Out bearing buddy. I thought i heard it the other day when we went to go eat. Easy fix, as the same happened to both James and my hatchbacks
Old Nov 9, 2003 | 07:44 PM
onlyNls's Avatar
Default Re: Chattering sound coming from tranny??? (OG Stunna)
weiird. I was just about to make a thread today about the same topic. Good thing I decided to look whats new in the Integra forum. I'm running into the same problem with my 98 GS.
Old Nov 14, 2003 | 06:36 AM
blacksheep's Avatar
ok guys.. new update.. I was driving my car yesterday to get something to eat and I had just pulled out into the road and was going about 20-25 in 2nd gear when something clicked and it popped out of gear.. and then this loud clicking noise started. So I went to my girlfriend's house and parked it and will not drive it anymore til I pull that tranny out and get whatever it is fixed. It still drove perfectly fine, but there was this loud clicking noise whenever I was not accelerating. Even if the clutch was pressed in or in neutral, the clicking would not stop til the car was fully stopped.. Any ideas??? I'm probably gonna pull the tranny out this weekend and take it to get it fixed next week.
Old Nov 14, 2003 | 06:55 AM
OVERBOOST TEG's Avatar
that would be one of your axles..or your trans axel..... same **** happened to me....its more likely to be your axle(s) ...if you continue to drive your car... where ever it finishes breaking ...you will have to have your car towed....have your girl bring you to a auto parts store they should have them in stock...it will only run you about $120 for both..if you bring your old ones back to them.....hopefully this helps out...good luck
always check the little **** before you go and rip out you tranny
Old Nov 14, 2003 | 09:11 AM
blacksheep's Avatar
Default Re: Chattering sound coming from tranny??? (OVERBOOST TEG)
Thanks for the input, but it's not the axles.. the sound is coming from the passenger side of the car, and I already replaced that axle.. plus it only does it when I'm decelerating. It's definitely inside the tranny.
Old Nov 14, 2003 | 10:49 AM
sorry to hear that man....but trannys ..are not my specialty....but good luck hopefully its something minor hey and you know what ...its friday mann!!!!! have a
Old Nov 16, 2003 | 09:04 PM
onlyNls's Avatar
well i noticed on my car theres a clicking noise when i decelerate/accelerate. But when i depress the clutch it goes away. Also, when my car is at idle i can hear it clicking and as soon as i depress the clutch it stops. I'm pretty sure its comming from the Tranny. Any ideas anyone?
Old Nov 16, 2003 | 09:20 PM
mmuller's Avatar
Mad Scientist
Default Re: Chattering sound coming from tranny??? (onlyNls)
it could be your output shaft main bearing
JT
Nov 1, 2007 08:52 PM
infamous_81
Dec 3, 2006 06:35 PM
Tjames8864
Nov 17, 2006 08:10 PM
Dirty GS-R
Sep 11, 2005 02:08 PM
blacksheep
Nov 14, 2003 11:10 AM
