Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Straight Weight Oil for Racing?
Old Nov 7, 2003 | 02:53 PM
Regular Series's Avatar
Default Straight Weight Oil for Racing?
I noticed some straight-weight oil sitting on the shelf the other day. Since changing your oil before and after a track day is recommended, what about some 30 or 50 weight? Would this provide any extra protection? I know it will not lubricate the engine as quickly on a cold start. I'd just like some feedback on this idea.
For reference, I have a basically stock 98 Integra RS.
Old Nov 7, 2003 | 03:01 PM
Todd Reid's Avatar
Default Re: Straight Weight Oil for Racing? (Regular Series)
i have never run anything other than 5w-30 in my honda racecars. never had an oil related failure, ever.
now, in my Super Seven, i run straight 50 racing oil in extremely hot weather. all other times, i run 20w-50 racing. thats an older engine with big clearances, tho.
for your honda, stick with the recommended oil. just my opinion, though!
Old Nov 7, 2003 | 05:44 PM
philstireservice's Avatar
Default Re: Straight Weight Oil for Racing? (Todd Reid)
good advice...could go to 10w30 in the heat...but don't have to as long as you are using a good synthetic
Old Nov 7, 2003 | 05:53 PM
OK, cool. Thanks for the advice.
Old Nov 7, 2003 | 08:03 PM
Knestis's Avatar
Although it's common practice, I have a hard time understanding the "science" behind the 10w-30 rather than 5w-30 in hot weather argument. The only difference in viscosity is at very low temperatures - way below operating temps.
K
Old Nov 7, 2003 | 08:16 PM
AKADriver's Avatar
Default Re: Straight Weight Oil for Racing? (Knestis)
conventional 5w-30 will generally start to break down at lower oil temperatures than conventional 10w-30, assuming an otherwise identical formulation. Even though they're both 30 weight at their operating temperatures, the 5w-30 will break down more quickly above operating temperatures because of the extra additives necessary to get the wider viscosity spread.
It's not much of an issue with synthetic oils, though. BMW specs 10w-60 synthetic for their M cars.
Old Nov 7, 2003 | 10:33 PM
ATS_Antone's Avatar
Default Re: Straight Weight Oil for Racing? (AKADriver)
all the newer M cars are using 5-30 again
Old Nov 8, 2003 | 05:29 AM
Default Re: Straight Weight Oil for Racing? (antone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by antone &raquo;</TD></TR><TR><TD CLASS="quote">all the newer M cars are using 5-30 again
It seems like most new cars are using 5w-20 now. Even the E-250 and F-150 we have at work use it. So what is it about my car that makes 5w-30 better for it?
Old Nov 8, 2003 | 02:20 PM
sykikchimp's Avatar
5w-20 is only for better emmisions, and fuel economy.. read here:
http://www.guarding-our-earth....shtml
Old Nov 8, 2003 | 08:13 PM
Default Re: Straight Weight Oil for Racing? (sykikchimp)
Good info, thanks!
spray004
Jul 10, 2017 11:15 AM
soloDC
Nov 29, 2011 01:08 PM
garage16.ca
Jan 30, 2009 01:29 AM
jmk2888
Oct 5, 2004 10:07 PM
fast4door
Dec 12, 2001 07:27 PM
