OIL
Old Dec 12, 2001 | 06:56 AM
fast4door's Avatar
Default OIL
what brand and what wieght oil do you guys run in you turboed cars. and what brand filter. just finished breaking in my engine now wondering if i sould go wit synthetic oil????
Old Dec 12, 2001 | 07:11 AM
Flamenco-T's Avatar
Default Re: OIL (fast4door)
mobil one synthetic 10W30
Old Dec 12, 2001 | 09:16 AM
98Psi ITR's Avatar
Default Re: OIL (Flamenco-T)
Mobil 1 synthetic 15-50
rtype11's Avatar
maybe try amsoil for one oil change after your beakin just for all the detergents to clean your motor a bit, then go to something like the Mobil - if you use stock honda clearances (tight) you can even run ) 0W racing weight in warmish weather.
VW's have like 0 compression if they run this, another testament to honda engineering.
Old Dec 12, 2001 | 10:17 AM
VTC_CiViC's Avatar
Default Re: OIL (rtype11)
Mobil 1 10w-30/15w-50 for the extreme heat during the summer time.
Old Dec 12, 2001 | 10:26 AM
brian b's Avatar
New User
valvoline vr1 racing oil 20w-50
Old Dec 12, 2001 | 10:37 AM
SiR Kid's Avatar
New User
Default Re: OIL (brian b)
Why such heavy oil guys? I'm running 10w30, and I've only had this problem.
On startup on a 30 degree weather day, when the oil pressure rose, I guess the turbo seals let some oil leak til it warmed up, cause it smoked pretty badly til it warmed up. Once warm, NO PROBLEMS out of 10-30 at all.
BTW, I'm using Castrol 10-30 non synthetic still with a Genuine Honda Filter bought at the Acura Dealer's counter... I've only got about 1800 miles on it and I'm going to change to synthetic at 2k or so. NO BLOWBY whatsoever. I didn't even have a breather filter on it, and there was NO residue or oil on the engine at all. I now have a breather filter! Thanks Exquivical.
Old Dec 12, 2001 | 10:50 AM
austrian type-R's Avatar
Default Re: OIL (SiR Kid)
what?! never heard of it. I doubt it.
Old Dec 12, 2001 | 11:12 AM
RGAZ's Avatar
New User
Mobil 1 5W-30
Always use synthetic on a turbo car, always.
Randy
Old Dec 12, 2001 | 11:20 AM
rtype11's Avatar
Default Re: OIL (austrian ITR)
Honda Tolerances are very tight the materials they use are all controlled expansion materials that expand / contract at the same rate. VW's use much looser tolerances its basically planned redundancy for longevity of their parts. try taking a golf 8V and replacing with 0 weight racing oil and taking the oil cap off the car will stutter and maybe even stall.
once of course you go to JE's you will burn a lot of oil during warm up enrichment cycle and carbon or dynamic turbo bearings may burn a little oil until operating temp is achieved.
Old Dec 12, 2001 | 11:23 AM
rtype11: cool sign! I have watched near all Pinocchio series when I was a little boy
Old Dec 12, 2001 | 01:18 PM
SiR Kid's Avatar
New User
rtype11, so your saying that the oil burning for about the first 3-4 minutes is normal?? I was so worried about it in the cold weather! It puffs pretty heavily...
[Modified by SiR Kid, 4:19 PM 12/12/2001]
Old Dec 12, 2001 | 03:17 PM
DLB1994's Avatar
20-50 castrol
Old Dec 12, 2001 | 04:37 PM
civicturbo's Avatar
I use synthetic Mobil1 5w-30 same oil I use in my Corvette.
Old Dec 12, 2001 | 06:28 PM
WykidEH's Avatar
Default Re: OIL (civicturbo)
Why "SYNTHETIC"?
Old Dec 12, 2001 | 07:27 PM
CivicV10@18000rpm's Avatar
Mobile 1 synthetic 0w-30 changed every 6000 miles.
floatfisher
May 28, 2006 11:46 AM
NightmareApex
Jul 27, 2004 01:44 PM
jbsmith
Jul 6, 2004 04:44 PM
ironballz
May 13, 2004 02:38 PM
RacerXintegra2k
Sep 12, 2002 11:34 PM
