Sunroof drain tubes, where are they?
Old Sep 8, 2001 | 04:51 PM
GruvyTune's Avatar
New User
Default Sunroof drain tubes, where are they?
The sunroof drain tubes are supposed to drain to the wheel wells. For the life of me I can't see where they pop out from? Where exactly are they?
Old Sep 9, 2001 | 10:32 AM
Paisan's Avatar
New User
Default Re: Sunroof drain tubes, where are they? (GruvyTune)
What kinda car?
Old Sep 9, 2001 | 11:09 AM
GruvyTune's Avatar
New User
Default Re: Sunroof drain tubes, where are they? (Paisan)
95 integra gsr
Old Sep 9, 2001 | 11:21 AM
Paisan's Avatar
New User
Try this, get a bottle of water (preferablly the ones with a closable squirter), open your sunroof, and squirt a little water along the insides of the sunroof. Then look at your wheelwells and see where the water is coming from. Keep a towel handy, just in case if the water spills into the car.
You can also do this, open your hatch, pull back the liner and locate the hoses. Follow the path of the hoses to locate where they are placed in the wheelwells. I hope this helps.
[Modified by Paisan, 2:27 PM 9/9/2001]
Old Sep 9, 2001 | 04:00 PM
GruvyTune's Avatar
New User
what hatch you talking about?
Old Sep 9, 2001 | 04:14 PM
Paisan's Avatar
New User
Ok, is your GSR a 4 door? If so, open your trunk then. Pull back the lining (carpet) on the side and you should see semi clear plastic tubes. Those are your drain tubes.
[Modified by Paisan, 7:21 PM 9/9/2001]
Old Sep 9, 2001 | 04:17 PM
GruvyTune's Avatar
New User
nope 2 dr
Old Sep 9, 2001 | 04:21 PM
Honda4CX-T's Avatar
They are built into the fron and rear pillars/columns, only way to get to them is by cutting the pillars in half or remove all of your interior and sunroof
Sorry but that's the only way my friend.
Old Sep 9, 2001 | 04:22 PM
Paisan's Avatar
New User
Hmmm my friend has a GSR. She and I pulled off the plastic mouldings and carpet and saw the tubes back there. Oh well, maybe those aren't it.
[Modified by Paisan, 7:25 PM 9/9/2001]
Old Sep 9, 2001 | 04:36 PM
GruvyTune's Avatar
New User
well, the dealer reamed the tubes out and fixed the leaking i was getting when it rained. they said they plug sometimes. since they did that i was curious as to exactly how to access them. I looked carefully and can't seem to see them.
skill178
Dec 29, 2011 11:59 PM
LeonardDB
14
Apr 12, 2011 08:57 AM
milanoredgsr
Feb 24, 2008 11:14 AM
Jun 10, 2004 08:56 PM
MisterB
14
Aug 13, 2002 06:02 PM
