WTF IS THIS NOISE? WTF
Old Sep 8, 2001 | 03:45 PM
Mr. Softee's Avatar
Default WTF IS THIS NOISE? WTF
its just to the left of where the stock airbox would be .. where hte abs unit is and the brake fluid goes in... umm i have no clue waht this noise is but it sounds like a really really loud annoying rattle / buzzz and it only does it before i start running hte car. Any ideas?
Old Sep 8, 2001 | 03:50 PM
Mr. Choi's Avatar
New User
Default Re: WTF IS THIS NOISE? WTF (97lstegra)
sounds to me like the ABS pump. this is normal on the newer cars, i dont know what year your car is, but it is nothing to be worried about. as your car gets older the pump will quiet down.
Old Sep 8, 2001 | 04:02 PM
Mr. Softee's Avatar
Default Re: WTF IS THIS NOISE? WTF (Chois i-VTEC)
mines a 94, but my motor only has 50k on it... hmmm think its bad? should i replace it? il take it to the dealer i guess on monday
Old Sep 9, 2001 | 12:59 AM
Anthony K's Avatar
New User
I have a 97 gs-r and when I start the car, sometimes I hear the buzzing noise. Even when I go over some bumps, the noise appears. I think it may be completely normal and is from the ABS system.
Old Sep 9, 2001 | 01:31 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: WTF IS THIS NOISE? WTF (GS-R916)
The noise you hear is the ABS pump pressurizing the system. Totally normal.
Old Sep 9, 2001 | 02:03 PM
90integraGS's Avatar
New User
Default Re: WTF IS THIS NOISE? WTF (B18C-EJ1)
Mine used to be totally silent...then the ABS warning light would come on intermittently(sp?). Then a while later this buzzing would happen(mostly over pronounced bumps). The ABS still functionally worked like it always had. I had it diagnosed at the Acura dealer and they said the compressor($1100) needed to be replaced in order to properly diagnose the system.
I removed the ABS fuses and I live with the ABS warning light.
Old Sep 9, 2001 | 02:28 PM
HokieITR's Avatar
New User
Completely normal.
Old Sep 9, 2001 | 03:39 PM
Erik95LS's Avatar
Default Re: WTF IS THIS NOISE? WTF (HokieITR)
normal
Old Sep 9, 2001 | 08:42 PM
miketegra's Avatar
Default Re: WTF IS THIS NOISE? WTF (DOHC ACURA)
My abs pump definitely buzzes more in colder weather...just thought I would add that. It also seems to buzz more if I am pressing on the break when I start the car (as opposed to having just the e-brake engaged).
You may want to test your ABS in an empty wet parking lot sometime. I have heard it is not a bad idea to engage the ABS every now and again to keep the fluid circulated through the system, but it could be some BS - anyone else hear of this?
Old Sep 9, 2001 | 10:56 PM
b18bvudoo's Avatar
New User
Default Re: WTF IS THIS NOISE? WTF (miketegra)
boy i'm glad i dont have abs.....yeah right
Old Sep 10, 2001 | 05:56 PM
wills94lsteg's Avatar
New User
I had the exact same buzzing noise coming from my ABS Pump... I don't see how anyone can say that noise is normal... Especially if you hear the noise when your driving... Well, mines started to act up after I replaced my front brakes and rotors .. After a few days the noise started and the ABS light was lite... I opened the lid of the ABS pump with the car "off" and filled it up with brake fluid (DOT 3) and the problem was solved... No more ABS light and no more of the so called 'normal' noise...
Good Luck
Mike1486
Jan 17, 2005 01:20 PM
1992gsrb17
Mar 24, 2004 03:00 PM
1992gsrb17
Mar 23, 2004 12:21 PM
social_control
Sep 18, 2003 01:54 PM
fiebru1119
Mar 7, 2002 01:13 PM
