turbo f22b1
Old Nov 7, 2003 | 11:03 AM
92ACCSIR's Avatar
Default turbo f22b1
I am going to turbo my f22b1 and I want to know what I should replace to make it a motor that will handle 10 psi max. rods,pistons,rings,etc. any help will work.
Old Nov 7, 2003 | 11:30 AM
Feddie's Avatar
Default Re: turbo f22b1 (92ACCSIR)
Whats your $ limit?
Are you doing the work yourself?
Old Nov 7, 2003 | 11:40 AM
matix's Avatar
from what i remember the f22b1 can handle 10 psi stock no problem.
Old Nov 7, 2003 | 11:57 AM
92ACCSIR's Avatar
yes i am doing the work myself but i have other people i can call if i need help. i am willing to spend the money as long as the motor will hold the boost. it is going to be 6 psi daily driven but if need be i want to raise it to 10 psi.
Old Nov 7, 2003 | 12:30 PM
fluxion's Avatar
amin n'rangwa edanea
Default Re: (92ACCSIR)
i'm pretty sure the engine will be able to handle 10psi without too many problems, you might wanna look into replacing the connecting rods to be on the safe side. 8psi at least is a non-issue on an f22b1.
Old Nov 7, 2003 | 01:16 PM
blackfrohatch's Avatar
Default Re: (fluxion)
yea i am running 5psi everyday no problem on a 175000 mile motor and it still runs good...i would make sure everything is in good mechanical cond.. then throw it in
Old Nov 7, 2003 | 04:04 PM
accordexchange's Avatar
Default Re: (matix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix &raquo;</TD></TR><TR><TD CLASS="quote">from what i remember the f22b1 can handle 10 psi stock no problem.</TD></TR></TABLE>
10 psi works for me with hondata stage 2b, p28 ecu, dsm 450cc injectors, and walbro intank 190lph fuel pump. f22b1 can take it-however, old and abused auto tranny cannot.
slammed_94s10
Sep 13, 2009 06:00 PM
MugenHonda
Apr 25, 2007 10:49 AM
93_delsol_si_gsr
26
Feb 10, 2007 12:10 PM
ENDGAME
May 20, 2005 08:47 AM
