best way to tune a b16?
Old Nov 7, 2003 | 08:03 AM
Drag-On's Avatar
Default best way to tune a b16?
hi,
donīt really know what to do with my b16.
iīve heard that it would be a good idea to put in the b17 crank. is that true? what else must/shoud i change?
it should be cheap, reliable and for a daily driven/weekend road race car.
Thanks
Old Nov 7, 2003 | 08:07 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: best way to tune a b16? (Drag-On)
Sure. For the specific class' I'm running I have to keep the stock block and head that came with the car. So the build up I'm doing this winter consists of a B17A crank, Crower B17A rods, Arias 85mm 12.6:1 pistons and RS 85mm sleeves. So basically a 1.85L. Compression will actually be about 13:1 w/ flat valves, mild resurfacing and the Cometic 85mm head gasket I'm using is like .004" less then stock. Portflow head and a stage 2/3 cam something with around 12-12.5mm lift and around 260-280 duration or so. Haven't decided on cams or valvetrain just yet. It'll make good power.
Old Nov 8, 2003 | 12:54 AM
Drag-On's Avatar
Default Re: best way to tune a b16? (Mr Milano)
could i use stock honda rods or do i have to take the crowers? which pistons will be good? how will the r/s ratio change?
Old Nov 8, 2003 | 09:39 PM
project92hb's Avatar
TTT b/c I want to know the same.
Old Nov 8, 2003 | 09:52 PM
Daysleeper's Avatar
Default Re: best way to tune a b16? (project92hb)
Well has wondered about some time...is valvetrain is that Valves,retiners and Valvesprings???
Old Nov 9, 2003 | 11:11 AM
B3AS's Avatar
Default Re: best way to tune a b16? (Daysleeper)
yes
94SiRswap
Mar 22, 2016 12:00 PM
Bwhit12
Sep 21, 2009 01:08 PM
b17 rolla
Sep 26, 2008 07:47 AM
Suck my DX
12
Nov 28, 2006 09:09 AM
1SlowB16EF
Apr 4, 2005 04:02 PM
