cam decision
Old Apr 1, 2005 | 05:48 AM
1SlowB16EF's Avatar
Default cam decision
i am currently running a b16 81.5 bore eagle h beam rods and 12.5 JE pistons ... i was planning on a little spray in the future is the reason i went with the heavy rods .. ok a lot! ... my question is with out claying my head which i dont want to do cause the engine is assembled now and in my daily driver with stock cams and valve train ... what cams would you suggest for my set up and not have to worry about piston-valvle cotastrophe .. i was looking at the blox and buddy club cams but i am scared to take that step from "stage III" to the IV ... any knowledgable input would be greatly appreciated ... ps i am running a stock head gasket!
Old Apr 1, 2005 | 07:28 AM
97L-esVeeTeg's Avatar
Default Re: cam decision (1SlowB16EF)
in general aftermarket pistons have some pretty deep valve reliefs, capable of supporting some pretty big cams if you are working with a unmilled head and stock deck. Something with a close to stock lift would be your best bet if you dont plan to clay, that way you know your ok for the most part.
Dont be fooled by the spec 3 in the buddy clubs, they are similar to other companies stage 1's, and the IV's are stage 2's.
With that being said, you should still clay!
Modified by 97L-esVeeTeg at 11:16 AM 4/1/2005
Old Apr 1, 2005 | 07:29 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: cam decision (97L-esVeeTeg)
The more the compression the bigger cam you can use... Just be careful.
Old Apr 2, 2005 | 02:23 PM
1SlowB16EF's Avatar
does anyone have a write up on the claying process for vtec ... ie how to engague while claying? .... lol i just read your location ... im orrigionally from iowa yea thats right IOWA! go hawks ... i am also looking into the BLOX cams anyone know anything about them?
Old Apr 4, 2005 | 06:41 AM
Default Re: (1SlowB16EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowB16EF &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a write up on the claying process for vtec ... ie how to engague while claying? .... lol i just read your location ... im orrigionally from iowa yea thats right IOWA! go hawks ... i am also looking into the BLOX cams anyone know anything about them?</TD></TR></TABLE>
Damn right..GO HAWKS lol anyhoo, the blox cams are skunk cams so choose accordingly.
Also c-speed racing has a great write up, you should visit the site http://www.c-speedracing.com.
Good Luck, i look forward to seeing some dyno numbers in the future
Old Apr 4, 2005 | 04:02 PM
1SlowB16EF's Avatar
hopefully this will be done soon .. i think i have settled on either the BC IV or possibly a rocket motorsports cans but dont remember the number ii think the m24 maybe i would have to ook at the specs again but right now i am going to get my piston to valve cleaance thanks to an ingenous idea from someone on this board named tbone thanks again man ... i need new ties and a distributer and a odb0-1 conversion harness and ecu and a new fuel pump and an alignment done all before i do the cams ... but should be all done in a month or so ...
honda92lude
Mar 14, 2010 08:32 PM
boosh
Jan 4, 2008 01:32 PM
killer_Bseries
Feb 14, 2006 10:34 PM
Used2beAb16
May 4, 2004 04:29 PM
