white/greyish smoke
Old Sep 8, 2001 | 01:19 PM
Mr. Softee's Avatar
Default white/greyish smoke
im getting white / greyish smoke outa my exhaust... whats the deal?
-sam
Old Sep 8, 2001 | 03:10 PM
FAST94GSR's Avatar
New User
Default Re: white/greyish smoke (97lstegra)
white smoke is usually blown headgasket.
Old Sep 8, 2001 | 03:14 PM
Mr. Softee's Avatar
Default Re: white/greyish smoke (FAST94GSR)
anyway to test this without takin off the head
Old Sep 8, 2001 | 03:29 PM
FAST94GSR's Avatar
New User
you can try a compressoin test and or look at your plugs.
Old Sep 8, 2001 | 03:39 PM
Mr. Softee's Avatar
did a compression test got 210 in each cylinder. Plugs look okay... i just put a new plug in the 4th cylinder and its white afte rlike 150 miles.,... hmm maybe htey're not okay
-sam
[Modified by 97lstegra, 4:40 PM 9/8/2001]
Old Sep 8, 2001 | 04:05 PM
quikrpm'z's Avatar
u found white stuff on the plug? Or are u saying that the insulator is still white?
Old Sep 8, 2001 | 04:10 PM
Mr. Softee's Avatar
Default Re: white/greyish smoke (quikrpm1)
it appears to be a chalky substance on the plug... its greyish white.
-sam
Old Sep 8, 2001 | 04:17 PM
quikrpm'z's Avatar
is it on the tip like little specs?, someone posted on that before. i cant find it though.
someone on here should know.
Old Sep 8, 2001 | 05:42 PM
DamonBoost's Avatar
New User
looking at this as a possiblity since my car is running like poop.. how much money am i looking at spending if i in fact have a blown head gasket too??
Old Sep 8, 2001 | 10:48 PM
Mr. Softee's Avatar
Default Re: white/greyish smoke (ill logic)
could it be my cat is too old? im putting out a TON of grey smoke.. like you dont understand...
Old Sep 9, 2001 | 07:58 AM
Luke's Avatar
You have tested the compression which should tell you if the rings etc are ok. What does the oil and water look like?. The smoke, sounds weird but what does it smell like?
civ97
Mar 31, 2009 07:56 PM
javon214
Jul 10, 2008 05:58 PM
ipleadthe5th
Aug 31, 2004 05:42 PM
SIK IN DA HED
Mar 23, 2003 02:09 PM
bitr364
Mar 10, 2003 06:53 AM
