JDM SiR-g Gauge Cluster - will this plug and play into my 94 Auto LS?
Old Nov 6, 2003 | 09:51 PM
jdmintegra1994's Avatar
Default JDM SiR-g Gauge Cluster - will this plug and play into my 94 Auto LS?
Hi...
Right now, I have a 94 Automatic LS. In a few weeks, however, i will be swapping in a GSR 5spd transmission. I'm thinking about getting an SIR-G cluster, but i'm not sure if this will 'plug and play' into my car since the gauge cluster is wired for an automatic.
Does anyone know if this will work on my car without modification to the cluster wiring? If i have to make modifications, what do i need to do?
Thanks in advance
Old Nov 7, 2003 | 06:21 AM
BolivianDc2's Avatar
Default Re: JDM SiR-g Gauge Cluster - will this plug and play into my 94 Auto LS? (jdmintegra1994)
I'm looking at the back of an SIR-G cluster right now, take out your cluster and see if it has two big blue connectors and one small connector. If it does, looks like your good to go
Old Nov 7, 2003 | 06:22 AM
Default Re: JDM SiR-g Gauge Cluster - will this plug and play into my 94 Auto LS? (Bolivianstrtwpn)
Depending on the year of the cluster you get, you might have either wire in the fuel gauge or put in the fuel gauge part of the cluster from your existing cluster. It sounds harder than it really is.
BTW i have one for sale check my sig
NZXTInerTia
Jul 24, 2013 12:35 AM
krnkwang
May 7, 2009 02:11 PM
91sicrxer
19
Mar 11, 2005 03:00 PM
chinkyEyez
11
May 21, 2004 01:51 PM
