ctr pistons in b16
Old Nov 6, 2003 | 08:56 PM
Beatkidd's Avatar
Default ctr pistons in b16
im thinking about putting in ctr pistons
in a jdm b16a2 will i have any problems since all the other internals are stock?
and this is a newbie questions but im in california will it affect my smog?
(for all of you that are mis informed you can smog and pass with a jdm motor
in california legaly )
any and all help will be much appreciated
also looking for ctr pistons hit me up with a price
in so cal
Old Nov 7, 2003 | 07:43 AM
PhatOptimo's Avatar
Default Re: ctr pistons in b16 (Beatkidd)
I've done it. I added ARP rod bols though. The rods have to be machined on the small end. 1mm off each side. I am running OEm cams with them too. Everything has worked out fine. I would recomend upgrading the valvetrain while your at it.
Old Nov 7, 2003 | 03:32 PM
radteg's Avatar
i did it too with everything stock. i had to shave off some of the rod and a tiny bit inside the piston there is a little lip that just shaved to make it flush runs good.
Pr0j3ctxH@tchx90
12
Jul 11, 2007 09:16 AM
Sean @ ESG
26
Jan 8, 2007 11:17 AM
toohott4handlin
43
Apr 28, 2004 01:27 AM
KoRE
Mar 3, 2003 01:04 PM
Sohc Driver
11
Mar 24, 2002 05:52 AM
