type r head swap
i kno this is a type r forum but the eg form is refusing to help me so, i was forced to ask you guys... i have a b16a2 that i want to boost eventually but in the mean time i wanted a little more power, i was considering swapping on a type r head, will it be a direct bolt on or are there major modifications needed, also would it be good for my boosting plans?
why not just build the valvetrain of the head you have? maybe add some cams or something?
the bare head itself is the same.. the itr one just has mild porting..
it will bolt right on though, if you bought a new one..
The ITR head is, however, cast with slightly larger ports than a b16a2. Look at the advantages and disadvantages of the situation, if you port your head and upgrade your valvetrain/cams/etc, then for the price of the ITR head you can have a head that will outperform just about anything you'll run into on the street. If you just replace the head with a complete ITR head, then you'll have either a spare, or something to sell to make back some of the money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by That Dood »</TD></TR><TR><TD CLASS="quote">sorry man but they are casted the EXACT same.</TD></TR></TABLE>
that and if you're going to boost.. look into other upgrades first, or i don't see why you'll even need something like this, other than valvetrain upgrade may help.
mynameizstitch
Apr 8, 2013 07:43 PM
MauiEg
Jan 19, 2006 03:35 PM
Good luck with your setup.
