auto to manuel?
Old Nov 6, 2003 | 07:27 PM
sir2k's Avatar
Default auto to manual?
I might swap out the automatic 1.5 for a D16 manual in my beater.
I've done my research but did not find much info on auto to manuel for 88-91 civics. I plan on doing this in a 4 door.
I was wondering if it would be just as difficult in a 89 4 door than other hondas?
Anyone have a link to a guide on the steps etc.
any help would be nice.
THANKS!!!!
Old Nov 6, 2003 | 07:33 PM
msrrex's Avatar
Default Re: auto to manual? (sir2k)
its real simple. you will need the 5sp tranny, pedal assembly, flywheel, shifter cables,ecu, .
Old Nov 6, 2003 | 08:11 PM
RCautoworks's Avatar
Default Re: auto to manual? (msrrex)
Stuff you will need
Manual trans
Manual flywheel
Manual flywheel bolts
Manual Ecu
Shift linkage
Shifter
Pedals
Side trans mount and rear trans mount from a manual, the pedals will probably be the hardest part. Here is some more wiring to help you out.
Installing the pedals (have fun):
This part sucks. Droping steering column and removing drivers seat makes life easier at this part. I cannot tell you how many nuts hold the assembly to the car, i can say it is all nuts though. One is really tricky to find and get to. You need a swivle, deepwell 12mm and 2 six inch extensions. It is above the air vents and steering column. Have fun getting it out. Remove cotter pin that holds brake pedal to brake booster. There is also a nut and bolt for it. Remove the gas pedal from automatic pedal assembly and move to manual assembly so the cable plugs up, or switch cable. Install the clutch cable through gromet that honda left on firewall in factory location. Rebolt all the nuts to the car that hold the pedal assembly.
Removal of the transmission:
To remove the transmission (you should know how to do this otherwise don't attempt). Please check my work with a chiltons or haynes manual as i will not be held responcible for damages that incure from this install. Remove both axels. Unbolt the bellhousing, remove the mounts (3 of them) and remove transmission, this is a unusually large tranny, it might require the whole engine coming out depended on how patient you are. I had the whole thing out cause i was putting a DOHC ZC in. Unbolt the torque converter from the motor, install flywheel (make sure not to reuse automatic flywheel bolts).
Installing shift linkage
This is a fairly simple task, remove the old auto shifter by removing 2 bolts on top and 2 on bottom. Then drill 2 holes where honda welded over them as picture below. Then simply install as a normal linkage would be. Take a piece of thin metal and glue to a piece of abs plastic and epoxy it on, the metal is to deflect heat and the plastic is to keep the heat form transfering inside.
Installing the transmission:
Torqure manual flywheel bolts down at 76 footpounds of torque. Install clutch with alignment tool, torque bolts down to 25 ft lbs. Before you install it all back there is one extremely important thing about the rear mount. Honda left 2 spots to mount the rear mount with 3 sets of holes, two are threaded, one is not. You need to move the mount location to the one that is threaded and then thread the other and place a bolt in there. Reassemble as specified in honda manual. Put new manual axels in.
Wiring with diagrams:
Drag two wires from under the hood (yellow and green on tranny) for the reverse lights to work when you are in reverse. Please note that the R light on the instrument cluster will not work without some decent knowledge of relay wiring. Connect these to wires to the ones pictured below
I found this one out the hard way, the key will not come out unless the car is in park and um, you dont have a park anymore. To fix this you can make the car think its in park all the time. Please understand, by doing this the P will be on in the instrument cluster all the time. This can be corrected one of 2 ways, disconneting the light or some extensive relay work.
This one is needed to crank the car because it no longer has a neutral or park. It is one of two plugs with only 2 wires. This one is easy to spot because it has two heavy black wires instead of the other with two yellow wires. Just connect them in a simple loop, or with some relay work to the clutch pedal because some decent current goes through them directly to the starter. I just left it like picture and allways crank the car with my foot on the clutch.
Old Nov 6, 2003 | 08:19 PM
redzcstandardhatch's Avatar
something different
Default Re: auto to manual? (90blackcrx)
yeah, very good write up. i just did this to my 89 4 door beater actually. i bought the car for 50 bucks.......etc. the pedal box was a pain in the ***.........had to drop the column, etc. its do=able, i'm glad i did it too.
Old Nov 6, 2003 | 08:36 PM
sir2k's Avatar
Default Re: auto to manual? (redzcstandardhatch)
wow. thanks all the replies.
I really hope it passes smog so I won't have to do the motor swap.
damn california dyno smog
Old Nov 6, 2003 | 08:40 PM
sir2k's Avatar
do I need that auto to manual transmission mount? even thought both motors will be D series?
Yeah, the auto and manual trans mounts are different.
Old Nov 6, 2003 | 08:46 PM
something different
yes, the rear mount that attaches to the cross member, not the one that the tranny is bolted to, the one that the tranny "horseshoe" mount slips over, is different. there are mount holes for the manual one already, take a look at a manual ef for a comparison....the auto one is just a tiny bit over to the right i believe
Old Nov 6, 2003 | 08:47 PM
sir2k's Avatar
oh, I meant to ask if I can just use a manuel mount and it would bolt up to the chasie. Or do I have to buy a converter mount for it? I think hasport sells them?
Old Nov 6, 2003 | 10:34 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir2k &raquo;</TD></TR><TR><TD CLASS="quote">oh, I meant to ask if I can just use a manuel mount and it would bolt up to the chasie. Or do I have to buy a converter mount for it? I think hasport sells them?</TD></TR></TABLE>
No the manual mounts will bolt right up to your chassis there are holes already there for it. If you look at your back mount you can probably see where the other hole is its just the front hole thats different the 2 back holes are the same. So no you dont have to buy anything from hasport.
Old May 22, 2005 | 07:06 PM
M15's Avatar
M15
Default Re: auto to manual? (Vinceg99)
Hey I'm doing the exact same swap, aand saw that you didn't need the mount from hasport what if it is an EG you still don't need the mount?
Old May 27, 2005 | 02:23 PM
accord2fix's Avatar
Default Re: auto to manual? (M15)
For an eg, I believe you have to buy the new mount. I remember it being about 1" off from each other.
Old May 27, 2005 | 02:55 PM
vegaskurt's Avatar
Default Re: auto to manual? (accord2fix)
FYI, auto 2 manual swap info is posted here. http://www.4gcivic.net
The passenger mount and rear mount are different on the autos. The front mount can be made to fit, but its also different on the autos.
BTW, best place I have found for mounts is to find an EF owner on this board that went with a B-series.
LeegodaEG
May 6, 2013 10:28 AM
Surferman
Jul 4, 2010 07:03 PM
ekoms31
11
Dec 8, 2004 11:52 PM
I Got an STD
May 3, 2004 03:42 PM
doh boy
Aug 12, 2003 04:36 AM
