Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
I need to know if 205's will fit on 14X6" rim
Old Nov 6, 2003 | 05:29 PM
Osokwik's Avatar
Default I need to know if 205's will fit on 14X6" rim
I have a set of 14X6" rims that were given to me just lying around in my garage and I need to buy tires for them to use on autocross weekends. I want to order them soon from Tireack but I need to know if I can order the 205's or do I need to stick with the 195's. I'm buying the Kumho Victoracers by the way.
Old Nov 6, 2003 | 05:33 PM
ZygSpeed's Avatar
Default Re: I need to know if 205's will fit on 14X6" rim (Osokwik)
The ITR folk have been putting 205's on their stock 6" rims for a long time.
Old Nov 6, 2003 | 05:34 PM
.RJ's Avatar
.RJ
205 or even 225 will fit just fine.
Old Nov 6, 2003 | 05:47 PM
Osokwik's Avatar
Default Re: I need to know if 205's will fit on 14X6" rim (.RJ)
Well if you say 225's will fit, then I guess I should go with the biggest one for better grip right? Where can I get a set of 225's? I was going to go with the Victoracers but I think the largest that they come in for a 14X6" is 250. I could be wrong; Ill double check.
Old Nov 6, 2003 | 05:54 PM
.RJ's Avatar
.RJ
tirerack.com should have a list of available sizes. I know toyo makes both a 205 and 225/xx/14 in their RA-1 tire. (tirerack doesnt sell toyo, btw).
Old Nov 6, 2003 | 06:06 PM
Osokwik's Avatar
Is there another tire option that will yield good results? I was originally sticking with either the Victoracers or the Azenis. Feedback as to which I should go with will be much appreciated .
Oh yet I forgot to ask if a 14" rim is good or bad? I just plan on using them because A: I have them and B: I thought that a 6" rim would be fine. Am I wrong for assuming this?
Old Nov 6, 2003 | 06:15 PM
.RJ's Avatar
.RJ
If you already had them, then go ahead and use 'em
What will they be used for and whats your experience?
Old Nov 6, 2003 | 07:18 PM
Timmah!!'s Avatar
It also depends on what car you are running them on. I don't think something like the 225s will fit on a stock(unmodified fenders) CRX or 4th gen hatchback.
Old Nov 6, 2003 | 07:25 PM
Osokwik's Avatar
Default Re: I need to know if 205's will fit on 14X6" rim (azroth)
I'll be running them on my 1999 Si. I have the stock 15's right now that I use w/ 195's. I've been autocrossing for 1 year now. I'm running in SM because of the modifications to my car.
Old Nov 6, 2003 | 07:32 PM
.RJ's Avatar
.RJ
I'd use the victoracers in 205.
If you can find a set of cheap 15" stock integra wheels, you can often pick up a set of 205/50/15 r-tires pretty cheap (used of course).
Old Nov 6, 2003 | 10:28 PM
smokin rubber's Avatar
a 205 will stick almost as well as a 225 on a 6in wheel, but the 205 will wear a lot better.
Old Nov 7, 2003 | 03:49 AM
Osokwik's Avatar
Default Re: (smokin rubber)
So in your guys opinion, either the 15" or 14" will work fine with the 205's. Not to get technical and all but if I can find a set of 215's, they might work out a little better.
P.S. If I'm running in the SM class will I be able to use the 14" rims? Will using them change my class?
Old Nov 7, 2003 | 04:34 AM
wheel size is open in SM
Johnny_fish
Honda CR-V & Element
May 4, 2018 10:25 PM
88ED8
Feb 7, 2006 07:23 AM
BuyImports2
Mar 19, 2005 04:35 PM
nutz4cycling
11
Jan 9, 2003 12:45 PM
N24RE
Jul 11, 2002 01:04 PM
