Clutch and Flywheel question
Old Nov 5, 2003 | 08:38 PM
speedracer9k's Avatar
Default Clutch and Flywheel question
I'm about to put in skunk2 stage 2 cams with skunk2 valve train componets with FPR and VTEC controller and get it dyno tuned. My question is since my clutch is starting to go out, would a ACT stage 2 clutch and fidanza 8 lb flywheel work good with this set-up, if not give me some ideas
thanks
Old Nov 5, 2003 | 11:58 PM
Gerhard_001's Avatar
Default Re: Clutch and Flywheel question (speedracer9k)
Stage 2 ACT? As far as I am aware they do not have Stages. As far as the flywheel is concerned go for it, I am not too fond of aluminum for a flywheel from what I have seen first hand but there has been some people pleased with the fidanza. I would recommend the 8.8 pound ACT flywheel chromoly steel is more durable than aluminum.
Old Nov 6, 2003 | 05:30 AM
LudeyKrus's Avatar
I would only get a lightened flywheel if I were going to track my car some.
I think you should just stick w/ an Exedy organic; you can get the kit for like $120 on ebay, and it's a more stout stock replacement, which is all you need since the stock clutch is good for 200 ft/lb's and you won't be pushing that.
Old Nov 6, 2003 | 08:47 AM
SKDRCR's Avatar
Default Re: (LudeyKrus)
i would just get the oem flywheel lightened too
Old Nov 6, 2003 | 09:09 AM
preluda92's Avatar
Default Re: (SKDRCR)
The Fidanza is awesome! Don't let anyone tell you different. Just, get the Exedy sport organic disc it's a little beefier than stock. I have the stock replacement, and it's great but, I've also got 225 tires and sometimes they are too much for it. a couple thousand miles into it and my new clutch slips on really hard launches.
Old Nov 6, 2003 | 11:42 AM
CleenSi
Guest
Posts: n/a
Default Re: Clutch and Flywheel question (Gerhard_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 &raquo;</TD></TR><TR><TD CLASS="quote">Stage 2 ACT? As far as I am aware they do not have Stages. As far as the flywheel is concerned go for it, I am not too fond of aluminum for a flywheel from what I have seen first hand but there has been some people pleased with the fidanza. I would recommend the 8.8 pound ACT flywheel chromoly steel is more durable than aluminum.</TD></TR></TABLE>
yea they do, 3 stages.
Old Nov 6, 2003 | 11:45 AM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">i would just get the oem flywheel lightened too </TD></TR></TABLE>
ohh ive heard stories about ppl doing that but they all say its really unreliable.
Old Nov 6, 2003 | 12:08 PM
RacingLude's Avatar
I have the ACT Extreme with a Fidanza 8lb flywheel. I love it. Revs very easy and is easy to drive with a little attention. My wife even drives it and she has never stalled.
The only negative I have noticed is if your going to down shift in to a high RPM the acceleration seems to pause for a second unless you rev match it. Which is what you should do anyway.
Tony
Old Nov 6, 2003 | 05:31 PM
Cottonwoodz's Avatar
Default Re: (RacingLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacingLude &raquo;</TD></TR><TR><TD CLASS="quote"> The only negative I have noticed is if your going to down shift in to a high RPM the acceleration seems to pause for a second unless you rev match it. Which is what you should do anyway.Tony</TD></TR></TABLE>
I have no idea what you are trying to point out there. I have a CM flywheel and exedy raceing clutch, and I have no pause in acceleration after I downshift into a lower gear.Its got way better throttle response, then when it had the stock flywheel. You might want to have your engine checked.
And, anyone that tells you that its hard to drive with a lightwieght fly.,., dont have one....Its the best Mod you can do, IMO.. Hell, they should of came stock with a 8lb fly
Old Nov 7, 2003 | 06:15 AM
RacingLude's Avatar
Maybe I do have a problem with my engine. Tell what you think.
If I'm going along in 4th at say 4K and shift into third and just dump the clutch, the engine pauses. Once the syncros match the RPM after you let out the clutch, it won't accelerate. It's not slipping because the RPM's don't go up.
As long as I give it some gas to match the RPM's and then let out the clutch without dumping it, no problems. It responds quick and pulls hard.
In nuetral the engine revs very quick. Plus I have modified my IM, TB, and head.
Tony
Old Nov 7, 2003 | 07:28 AM
v4lu3s's Avatar
RTFM
which clutch package is a stage 2 ?
ha3-hdss, ha3-hdr4, ha3-hdr6, ha3-xtss, ha3-xtr4, ha3-xtr6??
Old Nov 7, 2003 | 07:33 AM
SKDRCR's Avatar
Default Re: (CleenSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleenSi &raquo;</TD></TR><TR><TD CLASS="quote">
ohh ive heard stories about ppl doing that but they all say its really unreliable.</TD></TR></TABLE>
That depend's on how much you get it lightened
30k on mine
Old Nov 7, 2003 | 08:03 AM
RacingLude's Avatar
It was the Extreme 6 Puck. HA3-XTR6? I don't remember the exact number.
Tony
732xghost
Transmission & Drivetrain
Dec 4, 2014 08:15 PM
norcalB18
Dec 12, 2009 02:53 PM
treborpaul
Apr 20, 2009 05:08 AM
PBAndrew
Mar 12, 2007 08:04 PM
eg4life1202
Dec 29, 2006 11:28 AM
