I NEED OF HELP.....How can i tell if i have a CTR or ITR tranny?
Old Nov 5, 2003 | 06:21 PM
civicdohc's Avatar
Default I NEED OF HELP.....How can i tell if i have a CTR or ITR tranny?
as it is stated above. do CTR's and ITR's have the same LSD? i need to change it i think. my axle pops out just a little, not completely out but like a 1/4" out of hte tranny (passenger side) as it spins. my friends say its the differential. anyone got an idea of what it could be? also the half shaft wobbles quite a bit too. please help
thanks
Old Nov 6, 2003 | 05:14 AM
u0f's Avatar
u0f
Default Re: I NEED OF HELP.....How can i tell if i have a CTR or ITR tranny? (civicdohc)
the usdm itr tranny has the same lsd as the jdm ctr. i think the jdm itr's lsd is different.
Old Nov 6, 2003 | 08:52 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdohc &raquo;</TD></TR><TR><TD CLASS="quote">do CTR's and ITR's have the same LSD?</TD></TR></TABLE> i think so.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdohc &raquo;</TD></TR><TR><TD CLASS="quote">my axle pops out just a little, not completely out but like a 1/4" out of the tranny (passenger side) as it spins.</TD></TR></TABLE> not good. you may have worn or stripped splines inside the tranny (lsd) or you may have no C-Clip at the end of your axle (the end plugging into the tranny). Or you might not be seating it into the tranny enough, is this your first axle install? did you get it in there enough? did you use a new C-clip? are you using the correct length axle?
good luck dude.
and CTR's may have a smaller differential ring gear than the ITR's so might want to research that fact before you buy an ITR LSD that may or may not include the diff ring gear
million
13
May 22, 2007 07:11 AM
reactiondc2
Sep 21, 2006 08:52 AM
vtec25
14
Mar 14, 2006 08:26 PM
Ben_si
Jul 29, 2005 08:41 AM
civicdohc
Nov 6, 2003 11:33 PM
