Oil catch can for NA motors
Anyone running one?
Yea I kno it's more suitable for those turbo guys.
I wanna run cleaner oil cuz every oil change (like 2,700miles) it looks like black coffee
Any non-benifits, somethin that can hurt me?
An oil catch can isn't going to help your oil look cleaner. What it does is catch the oil coming out of block and/or head and holds it til you drain it instead of having it dumped back into your throttle body/intake manifold where it will mix with your air and fuel.
Try running mobil drive clean. I just tore down a block a week or so ago that was running mobil drive clean. That was the cleanest motor I have ever saw!! New motors out of the factory aren't even this clean! For real.
There are a ton of ways in doing this what were your ways?
Some people used the pcv valve on the head and the one on the intake pipe.
Some people used the pcv valve between the 1st 2nd fuel injectors and the pcv valve on the intake manifold
Some people drilled into the head with 2 nipples and used those for input/output lines
Which would be the best way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLeePeR012 »</TD></TR><TR><TD CLASS="quote">Anyone running one?
what are you talking about. do you know what a catch can does? its not an oil filter . BTW what color is Oil suppose to look like after 2700 miles.
YoungKadafi
Aug 5, 2006 03:59 PM
