changing oil after seafoaming, only in vaccum?
so i seafoamed my car a few times through the intake using deep creep, and also through the PCV port, let it savor for a few hours and cleaned the B out by revving. Well im now hearing even if you do it only through the intake, you still have to change oil, i just changed my oil like 4 days ago....is this true?
i only ask because i used 1/2 can of deep creep into the Throttle body and PCV port on the IM, now its really hesitating, but sometimes has way more power than before, but mostly hesitating and being extremely raspy
all the carbon blow by will go straight into your oil, and any excess sf will shear and thin your oil. change your oil regardless of how you seafoamed your car. increased insoluables and flashpoint of oil is not good and thats what happens after a seafoam. do an oil analysis right after doing a vacumm hose seafoam and you'l see a spike on the insoluables and the flashpoint will decrease (meaning there's undilluted 'fuel' in the oil).
tensai717
12-09-2001 03:49 PM
