ITR sway worth it on 99 Si?
To begin, Yes I already searched!
What is the size of a stock swaybar on 99 Si, and what kind of improvement would I see by getting it. With a beaks kit, of course!
Any experiences posted are appreciated.
front sway or rear?
if its the rear, go for it, the stock si is a puny 13 or 16 mm i forgot.
but if its the front, your wasting your time, your stock sway is the same size as the EK9. 26mm
stock Si rear sway bar is 13mm. stock gsr rear is 14mm and us itr is 22mm. jdm itr is 23mm. get a beaks kit with 22mm sway bar will be nice. make sure u have some stiffer springs/shocks to go with it
Thanks for the help. That helps a lot.
By the way, it is for the rear. I didn't know beaks made a kit for the front.
Synthesis
Mar 24, 2003 02:04 PM
