axle coming out . . . . tranny going?
Old Nov 4, 2003 | 06:43 PM
TegBen's Avatar
Default axle coming out . . . . tranny going?
ok guys, heres the conditions, or symptoms rather
it starts off driving normal, but the rpms get tricky and tach crazy all over the place . . . . then you can actually feel the axle coming out, because im getting no power to the ground . . . . i replaced the whole axle assembly ( its the passenger side) and it was back to problems by that night . . . . . a local guru around here says its my differential . . . . and 2nd's being a bia due to my synchronizer. . . . however . . . I've been told i need a new tranny because replacing the differential and synchronizer would be more than it's worth . . . . so id like some advice, info, etc on what to do, or if theres a cheaper alternative
all this is in my 92 hatch with a 1.5 vtec zc motor and tranny . . . . ive priced a si tranny for around 350 . . . . . so what to to . . . . thanks
Old Nov 4, 2003 | 06:48 PM
HXvtec's Avatar
Default Re: axle coming out . . . . tranny going? (HHB 2185)
correct if im wrong please but differential. i know some toyotas have final drive(front diff) but im not to sure if u have a diff. maybe your oil rings are bad.
Old Nov 4, 2003 | 06:57 PM
TegBen's Avatar
Default Re: axle coming out . . . . tranny going? (HXvtec)
im positive that i have . . . . (omg) . . . sorry . . . . a diff. and i dont know what oil rings you speak of . . . maybe you could elaborate on that some more . . .
in the mean time . . . . anyone else know what the deal is ?
Old Nov 4, 2003 | 06:59 PM
HXvtec's Avatar
ok the rings where between the tranny and the axle. where the axle goes in the tranny
Old Nov 4, 2003 | 07:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
there is a snap ring or there is supposed to be one on the end of the splines. is it there? if it isnt thats why it keeps popping out. and if its not, you are in trouble too because it is probably getting munched up in the tranny.
Old Nov 4, 2003 | 07:12 PM
HXvtec's Avatar
Default Re: axle coming out . . . . tranny going? (boostedcivicsir)
just buy a new tranny for a few hundred bucks
83rolla
Oct 19, 2012 09:33 PM
nicknack25
Nov 5, 2010 08:06 PM
Dann6968
Jan 9, 2008 12:47 PM
rexxb16
Aug 29, 2007 09:56 AM
*Boostwerks*
19
May 3, 2006 09:20 AM
