Would a fully built B20 12.1 comp. block not be able to work on a stock head w/ stock cams?
Old Nov 4, 2003 | 09:46 AM
BLK JDM's Avatar
Default Would a fully built B20 12.1 comp. block not be able to work on a stock head w/ stock cams?
I have just purchased a fully built B20 bottom end that was previously B20/VTEC. Will my stock 98 USDM B20B4 head w/ stock cams be able to run on pump gas(93 octane)?? I heard this would not be a good combination and the car would need race gas??!!
Here's the block specs
fully build 98 B20B block
Golden Eagle 85mm sleeves
85mm Endyn Rollerwave 12.1 pistons
Endyn/Eagle Rods
ARP rod bolts
ARP headstuds
ITR water pump
Z10 block girdle
ACL bearings
I will do B20/VTEC later right now my $$ is short. And sorry for the repost I need these answers fast so I can either put this block in or sell it and get something else.
Old Nov 4, 2003 | 10:27 AM
RS_H22's Avatar
Default Re: Would a fully built B20 12.1 comp. block not be able to work on a stock head w/ stock cams? (jig
The overall cc count of Combustion chamber volume in your b20 head is alot higher than a B16/18C head... More cc's in the cumbustion chamber from one head to another = lower compression...
Just guessing with this one becasue I dont have the numbers in front of me but Id say your compression will be in the 11.2:1 range... (just a guess)
So yo answer your question, you should be fine...
Modified by RS_H22 at 2:05 AM 11/6/2003
Old Nov 4, 2003 | 10:54 AM
BLK JDM's Avatar
Thanks I'm really hoping you're right cuz I'm gonna start on this tonight.
Well you work for ImportBuilders-yall are very reputable so I believe you. Thanks man. I really needed to know that.
Old Nov 5, 2003 | 10:26 AM
guapo's Avatar
which is better an ls block or a b20b block
Old Nov 5, 2003 | 01:11 PM
BLK JDM's Avatar
Default Re: (guapo)
The B20 and LS share the same head. The head and block are actually both the same. The B20 just has a larger bore and pistons.
Hope that helps because I still keep hearing different answers to my question.
Old Nov 10, 2003 | 08:52 AM
Hatch-E's Avatar
Default Re: (jigga008_99)
so... you might be able to leave me behind after all
Old Nov 10, 2003 | 11:32 AM
BLK JDM's Avatar
Default Re: (Hatch-E)
Maybe, I can't ever be sure about anything these days. When it's done then I'll call it.
Jhobs3
Feb 4, 2013 10:45 AM
vtak2nr
Jun 22, 2011 06:49 AM
93Hatchbackcivic
Aug 10, 2004 01:30 PM
boostin4door
Apr 21, 2004 06:38 AM
GreenGSR
Nov 25, 2002 10:34 PM
