Need Help?? Anyone replaced there speed sensor??????
I believe my speed sensor is messed up in my speedometer, cuz its not clocking right and just bounces up and down between 20-40mph.
Anyone have any diagrams or tips when replacing that sensor?
And where could i get one for cheap and how much do they run?
Info is greatly appreciated.
What kinda car is it?
It's on your transmission and it's really easy to change.
2 10mm bolts and it comes out.
if you speed sensor is messed up you should get a cel....
to take it off just take off your intake and then reach down directly under the throttle body... there should be a long 10mm bolt sticking up higher than the others...take off that long one...after that bolt is out then just pull up...
its as easy as that...
Not to sure what a cel is?
Is that kinda like the check engine light or ?
The car is a 1997 Honda Civic Cx Hatch with a manual tranny......
