h22a4 into EK -- What Distributor To Use??
hey im doing a 00' h22a4 into my 99 civic using a conversion harness to obd1 and p13 ecu. What distributer should I use? the 00' h22 distributer is external coil, should I look for an obd1 usdm or jdm h22 distributer? will one from an h23 work etc? thanks in advance.
charles
charles
i have the EXACT same thing as u. and i was using the 00 usdm ext. coil obd2 dizzy with a conv harness and a jdm p13. worked good.
but i wanted to get rid of the external coil.
so..
i just finished changing it over to a jdm internal coil, obd1 dizzy. works good too.
and i wouldnt reccommend one from an h23, it may work, but im not sure, from everything i've checked, its best to go with one designed for the h22.
if u need more help lemme know.
so..
just curious, how come you wanted to get rid of the external coil? how did you end up using the 00' one at first. i also pmd you.
thanks
charles
thanks
charles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">the h23a1 and h22a1 distributors are the same.</TD></TR></TABLE>
i didnt know this. cool.
the usdm ext coil dizzy was the only one i had. so i used it and made it work. <U>(had to rewire the engine harness, and modify the mounting bracket on the dizzy, had to make the holes in to slots so that i could turn the dizzy for timing.)</U> but then from taking it apart so many times, i ruined the oil seal inside it, and the dizzy had oil leaking out of it.
plus i think the engine bay looks cleaner with out the ext. coil.
so i got the jdm dizzy.
now it looks good, works good, and is adjustable for timing.
im working on write up that i will post soon, with some good pix too.
alright bro, u got email and also u can go here if ur friends need to refer to ht also.
https://honda-tech.com/zerothread?id=650329
its a few posts down ok.
i will try and add pix either today or tomorrow.
brad225
Apr 7, 2008 05:42 PM
99, civic, conversion, distributer, distributor, distributors, dizzy, ek, h22, h22a4, h23, harness, honda, im, rewire
