need help with vtec....(not a how to)
Old Nov 3, 2003 | 07:03 AM
EG_93Civic's Avatar
Default need help with vtec....(not a how to)
I have a problem with my top end. For some reasons, when i slowly rev up to redline, my vtec feels like it cuts off around 6800-7000 rpm. But if i just punch the gas down and rev to redline there isn't any cuts off. I have no idea what's wrong so please help...thanks....
Old Nov 3, 2003 | 08:21 AM
91civicDXdude's Avatar
what are you doing revving to 7,000 on partial throttle anyways? that will lead to a lean condition and probably detonation.
Old Nov 3, 2003 | 10:36 AM
EG_93Civic's Avatar
Default Re: (91civicDXdude)
so what can i do? i guess i've learn not to rev on partial throttle...
Old Nov 4, 2003 | 07:02 AM
EG_93Civic's Avatar
so, no one can help me? I seriously dont know what's causing the vtec to cuts off. I mean there's no sign of any problem, like check engine light, temp., etc.
Old Nov 4, 2003 | 08:19 AM
manson's Avatar
Default Re: (EF_89Civic)
itsn't vtec only activated on WOT? if thats true then if your a partial throttle it wouldn't be activated.
Old Nov 4, 2003 | 09:27 AM
JonGP4's Avatar
Default Re: (mansonclubpuir)
nope VTEC should be one as long as your moving and its at the right RPMs.. it could be a bad VTEC solnoid or low oil.. if everything is not in the right conditions the ECU will not let VTEC engage or cut it off.. first thing i'd do is hook up some kinda test light.. just to see if VTEC really is cutting off.. or your not just leaning out or something. IT could be something like clogged injectors.. its hard to tell.. first things first check to make sure what ur saying is accurate
Old Nov 4, 2003 | 09:30 AM
Brownjd's Avatar
correct me if i'm wrong, but vtec activates based on a few things such as oil pressure, rpm, engine load, speed, so if you aren't meeting all those conditions when your just hanging out around 7000 you might not be in vtec. so basically don't pay 7k a visit unless your at WOT
Old Nov 4, 2003 | 04:09 PM
EG_93Civic's Avatar
Default Re: (Brownjd)
sorry, what does WOT means? and i think i might have find out what's wrong. my rpm guage is not reading correctly, so when i fit that hopefully it'll solve my problem. thanks....
Old Nov 4, 2003 | 04:12 PM
fourthgenhatchB17's Avatar
WOT = wide open throttle
Jizzmaster Zero
Oct 1, 2005 09:08 AM
ATF Kuk
May 1, 2003 12:20 PM
DocV
Jan 10, 2003 06:58 PM
Keane Rated R
Apr 22, 2002 05:47 AM
