is it bad to "slip" a puck clutch
Old Nov 2, 2003 | 07:03 PM
SiRkid's Avatar
Default is it bad to "slip" a puck clutch
Have had my Action 2md in for just over a week. Love it so far!
great clutch, and very streetable!!!!
my only concern is when daily driving, i can basically slip it to make it engage smoothly.
Like I can feel it kinda of chattering(no sound but you can feel it wanting to grab) so ill hold it there for a second and the car will start to move then ill let it all go and it will engage smoothly. it doesnt always make that chatter feeling, but sometimes it does. other times i basically drop it at 1200 rpm and and somewhat lurches forward but not too bad
Im just wonderring if letting it rub the flywheel like that will wreck the flywheeel or clutch pucks themselves?
NOTE TO ALL: the action clutch DOES NOT really chatter at all. No noises, nothing violent..just a slight vibration and feeling of it wanting to grab onto the flywheel.
so dont get yourself confused !
Its a great clutch
Old Nov 2, 2003 | 07:19 PM
MADEINIRAQ's Avatar
Default Re: is it bad to "slip" a puck clutch (SiRkid)
i have the same clutch.. and drive it like you described.. I kinda let it slip a little..
I'm sure letting it slip at low speed/ low load isn't goint to harm anything as much as a launch would.
ps.. I LOVE my 6puck unsprung.
Old Nov 2, 2003 | 07:39 PM
BlueSi2k's Avatar
Default Re: is it bad to "slip" a puck clutch (madeiniraq)
got the same clutch too...drive it the same way. Its such a low load that I really dont think it will matter. Its really a great clutch though.
Old Nov 2, 2003 | 08:30 PM
Devine's Avatar
Default Re: is it bad to "slip" a puck clutch (BlueSi2k)
Sorry, completely off topic...but does anyone know if action makes any of these awesome clutches for D-series trannys? TIA
Old Nov 2, 2003 | 09:00 PM
SiRkid's Avatar
Default Re: is it bad to "slip" a puck clutch (Devine)
talk to 2k_teg
hrmm. alright seems to be ok.
I figured it woudl be but I just wanted to make sure
awesome clutch so far
Old Nov 2, 2003 | 09:14 PM
the-anti-crack's Avatar
thats the same way i drive me CM stage 5, no problems yet.
Old Nov 2, 2003 | 11:55 PM
swlabhot's Avatar
I have the same 2MD and do the same but sometimes the clutch bites suddenly making a chirping noise and the car lunges forward. I have to 'deglaze' the wheel now and again to stop/minimise this undesirable effect.
Old Nov 2, 2003 | 11:59 PM
Drew Peacock's Avatar
Default Re: is it bad to "slip" a puck clutch (swlabhot)
Well it will chew through your flywheel if you slip it but it just a trade off, your more likely to break your tranmission if you drop the clutch all the time engine mounts will wear out real quick to. But try and slip it as little as possible.
Old Nov 3, 2003 | 05:36 PM
Mista Bone's Avatar
D Tranny Guru
Bisi used a Action 6 puck sprung disc to run 10's. Used for 4-5 years.
I know what clutch I'm going with.
Old Nov 3, 2003 | 11:11 PM
blackANESE's Avatar
Default Re: is it bad to "slip" a puck clutch (Mista Bone)
I just got the 1MS (sprung 6 puck) hopefully these are as good as everyone says
Jmumblez2001
Aug 8, 2006 12:05 PM
xunkn0vvnx
Mar 9, 2005 01:47 AM
Stock@$$GSR
Dec 16, 2003 03:05 PM
Goldfingiz
May 1, 2003 07:54 AM
jeebusm3
May 5, 2002 12:20 AM
