A6 crank versus Z6 crank?
Old Nov 2, 2003 | 06:17 PM
soundman's Avatar
Default A6 crank versus Z6 crank?
I am geting a whole Z6 engine for my CRX SI. I have a turbo, and I'm building my engine up towards 260-280 horse. My question is: should I go with the A6 crank or the Z6 crank? Are they the same or are they interchangable, or what?
Old Nov 2, 2003 | 06:47 PM
USDM 4G VTEC's Avatar
Default Re: A6 crank versus Z6 crank? (soundman)
the cranks are intercheangeable
but i would use the Z6 one IMO
some people say the A6 one its more stronger..... but i like the Z6 better....
stock rods are going to lik eabout 200 hp only..... so get new ones if u want way more......
Old Nov 3, 2003 | 09:35 AM
soundman's Avatar
I am actually going with eagle rods, and forged pistons. I'm building everything up, I just wasn't sure about what the best crank was.
Old Nov 3, 2003 | 04:54 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (soundman)
depends if the A6 crank has the small snout. Make sure you have the correct pulleys if it does.
Old Nov 3, 2003 | 05:41 PM
89a6T's Avatar
what do u mean by snout? and how much stronger are d16a1 rods/will they fit a6 crank?
Old Nov 3, 2003 | 06:48 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (89a6T)
some of the early D15/D16's have small snout.
ZC rods are the same strength as every other stock D16 rod.
Old Nov 3, 2003 | 07:44 PM
1990civicsiguye's Avatar
alright to clear this up from what i understand just use the crank and the same crank pully for that motor hence if it is a 91 dohc zc then use the same crank pully then 91 dohc zc pully that is what i understand all this to be some interchange but if you have both then just use the correct one....
Old Nov 3, 2003 | 08:01 PM
CRX Si's Avatar
Default Re: (1990civicsiguye)
good question... I just got my A6 crank today for my built mini-me turbo
OnebadJdmEg6
Old Nov 4, 2003 | 06:01 PM
soundman's Avatar
I have a 90 CRX SI... I am sure the A6 crank is sufficient, I was just wondering about the differences... Thanks for the replies
Old Nov 4, 2003 | 06:51 PM
turbo sol's Avatar
there are slight differences in the rod journal dia. so check out the oil clearances when mixing rods and cranks.
AntDaKrilled
Oct 17, 2014 02:13 AM
NowLoading94
Feb 4, 2014 11:23 AM
SpoonfedCivic
Feb 23, 2011 07:30 AM
maddog20
Oct 29, 2003 03:00 AM
