Turbo on a d16 and then moved to a k20 swap????
Old Nov 1, 2003 | 02:44 PM
ramz7887's Avatar
Default Turbo on a d16 and then moved to a k20 swap????
Turbos are interchangeable between cars right? All you need to do is put the turbo on a new exhaust manifold that will fit a different motor? I want to put a turbo on my d16 but i want to later be able to put in a k20 swap in my ek. Do you think i would be able to put the turbo from my d16 on a k20? I figured i could use the turbo d16 untill i have saved enough money for a k20 and than when i sell the d16 just reuse the turbo. What do you guys think?
Old Nov 1, 2003 | 05:02 PM
JV's Avatar
JV
Who?
Default Re: Turbo on a d16 and then moved to a k20 swap???? (ramz7887)
You can swap the turbo over. You will need a manifold that is compatible with the motor, and the mounting flange on the exhaust housing of the turbo. (ex. T3 manifold with a T3/60-1, etc...).
Old Nov 1, 2003 | 05:45 PM
ramz7887's Avatar
Default Re: Turbo on a d16 and then moved to a k20 swap???? (JV)
oh
Old Nov 1, 2003 | 08:26 PM
Kamin's Avatar
also gonna need a new (most likley custom) downpipe
also redo the oil lines, etc etc etc
ticaaal70
Aug 18, 2010 08:38 AM
mandre800
Jan 26, 2006 09:06 AM
Turbo-Honda
Apr 6, 2004 04:47 AM
oMek
Feb 17, 2004 07:48 PM
