horrible limp mode
the setup is a d15b2 bottom y8 head
the problem is its in limp mode and i dont know where to begin diagnosing.
the car runs. NO CODES. it feels like there is no power after 5k. i had a friend of mine do the timing he said it was fine. fpr and guage are there and i am still running rich. spark plugs are fouling. ( bad o2 sensor???) what are the symptoms of valve leakage?? and a blown headgasket?? it doesn't over heat. help please.
thanks in advance ~!
when its in limp it will run rich, limp mode is a safe mode thats why its running rich and will mess with your o2, with my b16 I have two diff limp modes one is a severe one that wont let vtec kick in and the other one just sucks power say if an egt sensor is disconnect, all throw a check engine light though. also when i blew a headgasket it seemed fine other than a small amount of smoke, it showed up on the oil though. also try to have someone running a cylinder leakage test, it will show if anything is wrong, ie vavle leaking,rings, headgasket, and so on.
Boosted Gsr Hatch
Mar 9, 2003 06:48 PM
