91 integra?
Old Oct 31, 2003 | 02:08 PM
JMD's Avatar
JMD
Default 91 integra?
2 ?'s....what do i have to do to put the seats from a 91 teg ls into my 98 ex coupe and would it be easy to swap the auto tranny and b18b into my auto ex?
Old Oct 31, 2003 | 03:27 PM
SICKSOLSI's Avatar
Default Re: 91 integra? (siqcivic)
the motor would not be an easy swap due to its cable clutch...and the motor from a 91ls is B18A...B18B is 94+
Old Oct 31, 2003 | 06:14 PM
Newman's Avatar
New User
You need to swap the rails over (the easiest way) and even still they won't on there properly as EG/DC/EK seats are wider on the base but you can make them fit with some customizing. Basically same thing I ran into when putting JDM ITR Recaro seats into my 91 Integra.... if you drop them in as is, only 2 (in most cases) of the holes will line up.
Old Oct 31, 2003 | 06:18 PM
Ivan's Avatar
senior gold member
Default Re: 91 integra? (95excoupeMT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupeMT &raquo;</TD></TR><TR><TD CLASS="quote">the motor would not be an easy swap due to its cable clutch...and the motor from a 91ls is B18A...B18B is 94+</TD></TR></TABLE> he said auto. and to answer your question. the mount thats welded on the frame of the teg is different but I'm not positive. I would just find a newer engine and auto trans out of a 94 and up.
Old Oct 31, 2003 | 06:22 PM
Newman's Avatar
New User
Default Re: 91 integra? (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote"> the mount thats welded on the frame is different but I'm not positive.</TD></TR></TABLE>
On an EK Civic, they're all the same (engine bay layout). There's no "bracket" that sticks out on the framerail like an EG/DC engine bay. On the EK Civics, a brackets bolts up to the framerail so you can use either an auto or 5-spd chassis as they're the same in the engine bay.
Old Oct 31, 2003 | 06:23 PM
Ivan's Avatar
senior gold member
Default Re: 91 integra? (Newman)
yeah I knew about the EK but what I meant was the teg. I should rephrase that.
Old Nov 1, 2003 | 12:02 AM
Jdm_Rice_Monster's Avatar
I have tried to use 91 teg seats in 92 up civics and they never fit right. I know newer teg seats bolt in but you will run into some issues with the bolts lining up.
Old Nov 1, 2003 | 07:06 AM
JMD's Avatar
JMD
so will it just bolt right in with no big problems?
ericrx_88
Jan 13, 2010 12:26 PM
bone231
Jul 26, 2009 03:03 PM
ebp_dc2
Jan 14, 2006 04:39 AM
GSRWSU
Jul 2, 2005 08:27 PM
91sleeper
31
Apr 10, 2004 09:07 PM
